88 hood adjustment
Old Dec 9, 2010 | 12:42 PM
jameskarate's Avatar
jameskarate
Default 88 hood adjustment
I have an 88 and the hood is rubbing at the door edge. Is there any way of adjusting the hood rather than the door?
Old Dec 9, 2010 | 12:47 PM
sailorsteve's Avatar
sailorsteve
How does the hood fit at the front, at the bumper? If the fit there is good, you probably shouldn't move the hood.
Old Dec 9, 2010 | 01:05 PM
jameskarate
there is little more than an 1/8 gap
Old Dec 9, 2010 | 01:15 PM
sailorsteve
IMO you should not do anything that reduces that gap.
Old Dec 9, 2010 | 01:23 PM
jameskarate
I'll try moving the door. It's not rubbing by much
Old Dec 9, 2010 | 06:56 PM
Siveck's Avatar
Siveck
Maybe raise the rear of the hood a little? Be careful though as too much hood adjustment can make it difficult to open.
Old Dec 10, 2010 | 11:10 AM
samsonb's Avatar
samsonb
I believe you adjust the hood via the latch on the hood. And there are some rubber bumpers you can turn in and out that are located on the hood latch. I'd try unscrewing the rubber bumper which should leave the hood sitting a little higher. Then I'd guess you'd need to check if it still latches properly as that may need to be adjusted too.
Old Dec 10, 2010 | 11:19 AM
sailorsteve
Be careful not to make the latches too tight or you could break a release cable, then you will have bigger problems.
Old Dec 10, 2010 | 11:56 AM
jameskarate
Well I moved the latches and now I can't get the #!** hood open. I seen on the forum theres a hood tool for this problem. Are they available at local parts stores?
Old Dec 10, 2010 | 12:15 PM
samsonb's Avatar
samsonb
Try to pull up on the hood while you pull the release. Sometimes that works.
Old Dec 10, 2010 | 12:19 PM
jameskarate
yeah I tried that and even drove around with the latch pulled. What a dumb S#*T good news is the door doesn't rub anymore
Old Dec 10, 2010 | 05:20 PM
jameskarate
well i made a tool and that didn't work so swell. So I took wheel and inner panel out. so i adjusted the cables and put zip ties on the latches so i don't have that problem again. life is good Thanks to all
To 88 hood adjustment
