Front Oil Seals Replacement
Started with draining the Dexcool and yes, I made a heck of a mess
After I remove the basic; air ducts, disconnect all plugs it was time to remove the Camber Brace. If you have
one, you know how delightful it can be.
SONOFA8ITCH
The lovely water pump bolt behind the PS pump pulley.
H2O Pump out
This is the H2O pump oil seal. I installed it wrong to begin with. I did it wrong on my 95 3 years ago and I did it wrong
in my 96. I did not use the special tool, if you dont use it, the seals bends backwards and it doesn't seal...duh!
You will wonder why I dont get the balancer out of the way. The LT4 balancer is thicker that all others LT engines
and to remove it completely, you have to loose the rack & pinion. I was not going to do that today.
LT engines 92-96 Cancer
Obviously the Opti oil seal was leaking oil.
The J39087 Special Tool. "Shaft Front Cover Seal Protector"
New H2O Seal
Don't forget to install the new O-Rings for the H2O pump's shaft and the Opti's shaft.
Oil Seals Installed, no RTV. Yes, it was a PITA to do it with the engine inside.
I've done this few times, I got the opti in at the first intent. YEAH Baby--
The balancer is back up, tighten 3 bolts to 63 lbs ft.
I'll finish tomorrow. Its going to leak again anyways
Freaking LT engines, reminds me of the only animal on earth that bleeds every 28 days.
...14 days later thanks to the cold and rain finished it today.
This were I left of, the H2O pump was installed and torqued to specs.
The Camber Brace would not fit, I had to raise the Vette at the crossmember for it to "stretch" and for the shim to fit.
Water hoses and connections up.
Fill up with Dexcool, bleed system and test drive.
I'll drive more tomorrow then, I'll inspect and find out if this "surgery" was a success or fail.
This was my Christmas present.
It happened right away. I either installed the seal wrong or it came defective.
I love working on LT engines.
"Since 1997"
There is one thing I have not done yet...
Remove an Automatic Transmission
My 95 is auto, they day "may" come.
