Brake System Flush
Old Dec 12, 2010 | 07:22 AM
HlhnEast's Avatar
HlhnEast
Default Brake System Flush
While I am working on the clutch hydraulics I figured I would go ahead and flush the brake system as well. How many quart(s) of brake fluid will be sufficient to do this. I have a little vac pump if it makes any difference.
Old Dec 12, 2010 | 12:59 PM
GKK's Avatar
GKK
One quart is enough.
Old Dec 12, 2010 | 04:35 PM
HlhnEast's Avatar
HlhnEast
Thanks!
Old Dec 12, 2010 | 05:41 PM
oldalaskaman's Avatar
oldalaskaman
There's a preassure unit that looks like a mighty vac unit except they called it a "jet unit". It reverse flushes the brake system. When I was doing it for a living, I would reverse flush to the abs/perportioning valve and then preasure up thru the M/C. If you're not carefull, a little messy going thru the M/C but eliminated any chance of sucking air into the system and then having to do re-bleeds for left over air.
Old Dec 13, 2010 | 04:54 PM
HlhnEast's Avatar
HlhnEast
Luckily I dont hafta worry about ABS on my '85. I also dont hafta worry about a lot of horsepower either with the '85
To Brake System Flush
