Throttle Position Sensor Adjustable 1993 ??
Old Dec 14, 2010 | 07:31 PM
BIGJIM13's Avatar
BIGJIM13
Default Throttle Position Sensor Adjustable 1993 ??
Has anyone tried the 'adjustable' Throttle Position Sensor?
Is it any good or should I just replace with stock?
Old Dec 14, 2010 | 08:43 PM
aguiar's Avatar
aguiar
8th Gear
i had a problem with idle surge on my 91 change everthing on the dam thing went with the adjustable tps car never ran better for $50 can go wrong
Old Dec 14, 2010 | 09:40 PM
rodj's Avatar
rodj
I don't see what difference it would make.
The LT1 ECM takes the voltage figure it first sees when key turned on and uses that as the base TPS number.
Does not require setting TPS to .54V like the earlier TPI cars did
Old Dec 14, 2010 | 09:47 PM
neverendingprojects's Avatar
neverendingprojects
Seems appropriate,
I have been trying to work out bugs since I added a BBK 52MM TB, but assuming it is the same a my 92.. The FSM states that anything under .99 (if my memory is correct) is treated the same as closed throttle...
Old Mar 13, 2012 | 10:16 AM
GvilleFloridaC4's Avatar
GvilleFloridaC4
What brand sensor and where did you buy?
Old Mar 13, 2012 | 11:01 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
http://forums.corvetteforum.com/foru...s-or-more.html
To Throttle Position Sensor Adjustable 1993 ??
