Hardtop Installation problems
Old Dec 14, 2010 | 09:41 PM
ernie22golf's Avatar
ernie22golf
Default Hardtop Installation problems
Trying to install a hardtop on my 90 Vert - Got back bolts started but can't get front bolts to start - what do the 89 - 96 brackets and the earlier 86-89. I think someone has maybe retrofitted the earlier front brackets on hardtop. Haven't tighten anything but just can't get front started. Any help appreciated.
Old Dec 15, 2010 | 12:00 PM
ernie22golf
Default ttt
ttt
Old Dec 15, 2010 | 01:37 PM
Siveck's Avatar
Siveck
Undo the back and start the front bolts first. Shouldn't be that close if the wrong brackets are on there.
Old Dec 15, 2010 | 08:42 PM
Camelotian's Avatar
Camelotian
I agee. Start front first. Do not tighten all the way until front and back are started. Press down on edge of front to compress weatherstriping and start. Maybe use second person.
Old Dec 15, 2010 | 08:46 PM
dallas916's Avatar
dallas916
Definitely start up front and leave them about half loose. Hopefully, the glass-to-frame mounting job is accurate and it will fall into place. If not, you may have to start over at the frame and refit it all.
Old Dec 15, 2010 | 09:45 PM
ernie22golf
Default Needs adjustment - anyone know how to adjust?
I took everything loose and back out of holes and was able to get front started - it was about 1/4 inch off to the drivers side when back was started and then when front started the back connector pins wouldn't go in the convertible top holes - off by about 1/4 inch back there at least. Convertible top works great and is water tight so I think the hardtop has been bumped around during its life and needs to be adjusted which I suppose is done on the back connectors - anyone ever adjusted one? Maybe it's my car but it doesn't seem so - clear carfax and car all fits good so doesn't seem to have been in any real bad accident. Any help appreciated!
Old Dec 16, 2010 | 11:10 PM
ernie22golf
Default ttt
ttt
Old Dec 17, 2010 | 12:10 AM
dallas916's Avatar
dallas916
The dealership had to make adjustments between the frame and the lexan twice before my new one was correct. It's a bit tricky from what I remember because I think the bolts are under the part of the brackets we use to secure the whole thing to our cars. It's been quite awhile and I don't have the car anymore so I can't look at it to remember exactly what he did. I just know it did have some room to move and it made a big difference.
To Hardtop Installation problems
