Acessory drive belt
Old Dec 15, 2010 | 05:09 AM
Ant1981's Avatar
Ant1981
Default Acessory drive belt
Are they the same for an '85 and an '86? My local american parts store has tried everywhere and can only get one for the '86 at the moment, they're not listing one specifically for the '86.
My belt is just squeaky, quietens up with some belt dressing, but then it's not long until it squeaks again.
Old Dec 15, 2010 | 05:49 AM
HlhnEast's Avatar
HlhnEast
Get a piece of string and wind it along the belt then measure it. Most parts stores can take this measurement and match it with the right belt. Even if you get a belt listed for the '85 it may not fit. You may not know what a PO has done like underdrive pulleys or accessory eliminating set ups. Any mod or different installation may throw off the belt length enough to make the "book" size useless.
I did the AIR elimination to my '85 and had to go with a 1" shorter belt even when the directions to the kit said the OEM belt would work.
Old Dec 15, 2010 | 06:40 AM
ex-x-fire's Avatar
ex-x-fire
The internet is your friend, just after 30 sec google search I found that 85 through 87 use the same belt.
Old Dec 15, 2010 | 06:50 AM
Ant1981's Avatar
Ant1981
Thanks, I had a look at some parts websites but wasn't getting the detail I wanted. Some people are far better at searching than others. I've ordered a belt, hopefully have it for Friday.
Old Dec 15, 2010 | 08:14 AM
Muffin's Avatar
Muffin
Interesting length data from Rock Auto for both 85 and 86:
Gates.........89.50
Dayco........88.58
Goodyear...89.50
ACDelco.....89.50
So I guess anything between 88.5 and 89.5 would work.
To Acessory drive belt
