Need c4 upper control arm washers.
Old Dec 17, 2010 | 02:58 PM
radiowaves88's Avatar
radiowaves88
Default Need c4 upper control arm washers.
Hello, I am rebuilding the front control arms for a C4 and wanted to know if anyone makes the washers that go on either side of the control arm bushings. The originals were flimsy aluminum and I ruined all four on one side getting the old bushings out. I am using urethane bushings from Prothane and they tell me to use the old washers over again. I've checked with other urethane bushing manufacturers and they say the same thing. Does anyone here know where I can get replacments in either aluminum or steel. Thanks, Al.
Old Dec 17, 2010 | 03:31 PM
sailorsteve's Avatar
sailorsteve
Try www.corvettecentral.com
Old Dec 17, 2010 | 09:42 PM
blackozvet's Avatar
blackozvet
dont forget to put new nylock nuts on, if you dont they will come loose, Im too embarrased to tell you how i know this !
To Need c4 upper control arm washers.
