Nah wont make any difference really. You need more lift to take advantage of your heads, like lots more than you have now. once youre moving more air your note will change.
I dont get it even if I went with the 1.7 rocker arms using my trick flow 23 super 195 heads it not going to Help ???.
The cam in it has 447 lift with 1.5 arms if I go to 1.7 this will give me .507 lift with 290 duration @214
I just will live with it I guess untill I can see spending anouther grand for a roller cam set up or should I just put anouther hyd flat tappet in the car.
For $200.00
Your cats quiet your car enough to be legal. My stock engine has the sound you are looking for. I have no mufflers. Not a lope, but a deep throaty sound.
Marv, Its sounds good to me. I can listen to my music. It has a deeper pitch. When I went to get new mufflers, my muffler guy told me this is what to do. So he did this for me.
Can you talk to the passenger at normal tone or do you have to yell at each other.
my hearing aready not the best due to my job working around Jet Aircraft after all these years.
Marv, my 84 had eliminators on it when I got it. At cruise it wasn't much different than muffled, but around town the mufflers made a nice difference. It still drones some inside at low speeds (and mines' an automatic so that makes it worse) but once you're up past 1600 or so it's nice and "performance sounding" inside without being obnoxious.
Thanks Theres a member of anouther fourm thats going to help me out getting Real Hi Flow 3 way cat.
Like I said the smog guy not going to crawl under your car looking for a EO number.
I going to try this first then If I dont like that I going to try a Corsa system I sell my Magna Flow Cat back system.
It sounds like the Corsa has more rummble to it but at cruise it nice.
