'92 Keyless entry install. Any experience here ?
Old Dec 19, 2010 | 01:16 PM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Default '92 Keyless entry install. Any experience here ?
I'm considering a keyless entry for my '92 coupe.
My '93's PKE was great, but the '93's been sold.
Any suggestions on which one is best / easiest to install ?
I understand best / easiest do not always apply, actually very rarely does best / easiest apply.
Thanks in advance to anyone who want's to "chime in" and Happy Holidays to all.
Old Dec 19, 2010 | 03:13 PM
Marv02's Avatar
Marv02
I put one in my 1986 Vett not all that hard you can get a wiring diagam online if you look.
The only thing on the 1986 its a 5 wire door lock system I had to buy a adapter to use the keyless entry system.
I also instaled a remote starter system at the same time not hard just take your time.
Old Dec 19, 2010 | 04:44 PM
LaVidaLoca's Avatar
LaVidaLoca
Most will install about the same.
After you find what you want here is some install info.
http://batee.com/corvette/keylessentry/index.htm
It is about the VKE 1000 but the info applies to others. He has diagrams and information for Vettes.
Also check here:
http://forums.corvetteforum.com/c4-g...ent-panel.html
Chuck just got through pulling the wires and hooking his up.
Old Dec 20, 2010 | 10:47 AM
larry93lt1's Avatar
larry93lt1
Yes I've seen Chuck's post. His is an '87, mines a '92 I'm sure they are different.
I'm hoping to find someone with a '92 who has had it installed and can give me a "heads up" on what to expect.
Old Dec 20, 2010 | 03:18 PM
Deepa's Avatar
Deepa
http://forums.corvetteforum.com/c4-t...ntry-help.html
From my 1991. Works great. Hatch works too.
To '92 Keyless entry install. Any experience here ?
