Clutch Slave
Old Dec 20, 2010 | 02:22 AM
grantar2's Avatar
grantar2
Default Clutch Slave
Can anyone tell me what the symptoms of a degraded or failing clutch slave are? 90 L98 with ZF 6sp.
Old Dec 20, 2010 | 08:23 AM
sailorsteve's Avatar
sailorsteve
The trans will be difficult to shift into gear, especially into reverse. You should be able to shift into reverse while stationary without grinding gears or forcing the lever. The feeling is that of a clutch that is not fully released, because that is the result of trouble in the hyd. system.
Old Dec 20, 2010 | 08:49 AM
lt4obsesses's Avatar
lt4obsesses
also check the fluid level in the master resevoir. It is located on the driver's side just over the battery. You can also check underneath for dripping fluid from the bottom of the bell housing. If the slave is leaking, it usually does so into the bell housing and will work it's way out from the lowest point in the housing (just in front of the oil pan).
Along with the aforementioned symptoms, the clutch pedal will get progressively more spongy and will go deeper to engage.
Old Dec 20, 2010 | 09:41 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If I don't drive it I will be out of clutch fluid in a week.
Once filled with fluid it takes a LOT of pumps to get any pedal back.
One time I even had to crack the bleeder to get fluid flowing.
Thank goodness the 2010 season is over so I can replace all that old stuff.
Old Dec 20, 2010 | 10:35 AM
grantar2's Avatar
grantar2
Thanks guys.
Old Dec 20, 2010 | 12:40 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Your slave isn't bad if you're not losing fluid.
Old Dec 20, 2010 | 03:15 PM
sailorsteve
I agree with you and lt4obssesses that checking the fluid is the first thing to do, and I should have mentioned it. But, if the pushrod seal of either cyl is compromised, would you not have symptoms noted by the OP? Would you not then have internal leakage, not necessarily visible? That's how I interpreted the piece by Bill Boudreau (zfdoc) that is archived on the forum, and it seems to mirror my experience with clutch cyl problems.
Old Dec 20, 2010 | 09:57 PM
GREGGPENN's Avatar
GREGGPENN
What symptoms noted by the OP?
Old Dec 21, 2010 | 09:46 AM
sailorsteve
I must be bumped in the head, I confused this thread with another one on the same subject when I wrote my response.
Also, after rethinking your post and my recollection of my own clutch issues (6 yrs ago), I realize that if the pushrod seal craps out, and prevents a full stroke, the fluid that leaks by has no place to go, other than to leak out.
I'm just going to have to start going to bed earlier, or something.
To Clutch Slave
