stock l98
Old Apr 8, 2002 | 12:49 AM
BowTieBlood's Avatar
BowTieBlood
Default stock l98
what does a stock l98 vette (auto) run....
1/4 mile times
hp (crank and rw)
tq (" ")
thanks guys
Old Apr 8, 2002 | 12:54 AM
scorp508's Avatar
scorp508
I don't have an auto, but here is my stock dyno sheet. The 'big' curve is torque.
211.2 rwhp
315.1 ft/lbs
Old Apr 8, 2002 | 12:58 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: stock l98 (BowTieBlood)
Here are data from my '88 with A4 and 2.59 gears when it was bone stock, down to the Fram air filter:
Parameter.......Actual..............Norm alized
ET (sec)..........14.45..............14.04
Speed (mph)...93.98..............95.29
HP..................218................. 228
NOTE: Normalized means corrected for temperature & baro.
Launch weight was 3380lbs.
Old Apr 8, 2002 | 01:13 AM
BowTieBlood
Default Re: stock l98 (65Z01)
Awesome that's exactly what I wanted to know :jester
Old Apr 8, 2002 | 08:56 AM
Rich B.'s Avatar
Rich B.
I thought those figures were interesting, so I pulled out a Road & Track Comparison from March 1986, here's what they said...
BHP............230@4000
Torque........330@3200
1/4 mile.......14.4 @ 96.0
Top speed....154
Test Weight..3450
Final Drive.....3.07
(all with Z51 coupe & 4+3)
Old Apr 8, 2002 | 09:05 AM
Rich B.'s Avatar
Rich B.
Default Re: (scorp508)
I'm goint to print that out (Scorp torque curve) as that is exactly what I want - a torque curve that peaks early and then falls off. But I know Scorp has the '87 with a different [roller] cam than mine, so I'm going to have to see what I need to do to get that cam to work in mine...
I'm aiming for a "falling torque" curve.
(There was an interesting column in Cycle World a few months back on using "falling torque" as a traction device.)
Old Apr 8, 2002 | 09:13 AM
Jim85IROC's Avatar
Jim85IROC
Default Re: (Rich B.)
Using a roller cam in a non roller block is expensive, and a huge waste of money for what you're trying to accomplish. Roller cams are great because you can slam the valves open, keep them open, then slam them shut. But... GM didn't have that figured out when they made the L98 cams. That cam is only worth 5hp max over your cam, and it's going to cost you nearly $800+ to retro that cam into your car.
Old Apr 8, 2002 | 09:40 AM
Rich B.'s Avatar
Rich B.
Default Re: (Jim85IROC)
...for what you're trying to accomplish...That cam is only worth 5hp max over your cam, and it's going to cost you nearly $800+...
...That bad, huh?...
Well, what I have isn't all bad, but I don't have a curve to look at...Maybe R&T does; have to look...
Thanks for the reality check! :lol:
Old Apr 8, 2002 | 06:55 PM
KYVette90's Avatar
KYVette90
I ran a 13.9 @ 102 with the G-Tech. I don't know how accurate G-Tech is but that was on a road with a slight curve in it. I shifted at about 3500 rpms.I only have a few small mods and my engine has 150,000 miles and 2.59 gears. :U
Old Apr 8, 2002 | 06:59 PM
Kale's Avatar
Kale
My 86 ran 14.3 in HOT weather with a HOT engine :cheers:
Old Apr 8, 2002 | 08:08 PM
Jsailor24's Avatar
Jsailor24
I ran 14.01 at 98 saturday :D
Old Apr 8, 2002 | 08:12 PM
lampedusa's Avatar
lampedusa
Nice..
Old Apr 9, 2002 | 09:28 PM
GusBustamanteJr's Avatar
GusBustamanteJr
Default Re: stock l98 (lampedusa)
13.7 on mine
Old Apr 9, 2002 | 09:31 PM
scorp508's Avatar
scorp508
Oh I guess I forgot that ET part.
The car ran 13.89 @ 98.17 in stock trim with a small amount of wheel hop. In "lightly modded" trim she's done 13.48 @ 101.11 so far. I think thats the best you'll see from her like that because I think I'm finally pulling the heads/cam this week.
Old Apr 9, 2002 | 10:43 PM
jeffie86/96's Avatar
jeffie86/96
If you are interested in a cheaper roller cam drop me an email.
To stock l98
