1984 Corvette Wiring problem
Old Dec 22, 2010 | 03:16 PM
michaelrobinson2618's Avatar
michaelrobinson2618
Cruising
Default 1984 Corvette Wiring problem
I just recently bought a 1984 Corvette to restore. I'm having a problem with the battery not holding a charge and it wont start after two days of recharging the battery. I've replaced battery and alternator. I think I have a wiring problem. Something may be shorting out and draining the battery. I think it may be the starter but I'm not sure. Does anyone have anything that I could try to fix it.
I also Have another problem with my fan. The guy who had it before me rigged the fan to run constantly with the ignition on. does anyone have pictures of what is suppose to look like correctly so I can fix it back to the way its suppose to be. It is also missing the engine temp part for the fan and the coolant level switch stuff has been removed.
Old Dec 22, 2010 | 06:29 PM
vetteoz's Avatar
vetteoz
Originally Posted by michaelrobinson2618
wont start after two days of recharging the battery. I've replaced battery and alternator. I think it may be the starter but I'm not sure.
Need to confirm starter actually works first ( with a fully charged batt )
There are many things that will run a battery flat ( seperate problem )
A temp switch in head runs the fan.Replace switch and run wire from fan relay to switch
Old Dec 23, 2010 | 09:52 AM
michaelrobinson2618
Cruising
I have come to the conclusion that it is not the starter. I completely tore the car apart disconnecting every connector in the car looking for a faulty circuit by attaching a multimeter to the battery negative cable and the multimeter to the negative post on the battery. It is pulling 12.71V with the engine off. What is the normal draw on the battery. I disconnected all the fuses hoping that I would get something out of it. I still cannot find the short in the wiring some where. I know the alternator works because when I turn the car on and let it run the dash tells me I'm getting like 13.7 -14.3V. Would the ignition maybe be a problem?
Old Dec 23, 2010 | 09:53 AM
michaelrobinson2618
Cruising
thank you for the help with the fan. Its a big help. This car is driving me insane with all the problems. At least I got it cheap
Old Dec 23, 2010 | 03:11 PM
sailorsteve's Avatar
sailorsteve
There is a circuit somewhere that is draining your battery. Disconnect the battery ground cable and connect an ammeter from the battery to ground. With everything off, including courtesy lights, underhood lights, etc. the reading should be in the range of a few milliamps, but likely will show greater current. Pull fuses one at a time and watch for the current to drop, when that happens, that is the faulty circuit.
Old Dec 24, 2010 | 02:06 PM
danvetman's Avatar
danvetman
Great advice Sailor! I am having the same problem and have been lurking. I will give this a try. Just never thought about doing this and it makes prefect sense.
Thank you very much.
Old Dec 24, 2010 | 06:39 PM
rodj's Avatar
rodj
Be aware there are also power circuits fed direct from the batt ( starter terminal on early cars / jump start terminal behind batt on later ones ) that do not go through the fuse box.
They have inline fusible links
Old Dec 25, 2010 | 10:56 AM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default battery drain
Electic antenna could be pulling power. I disconnected the power to my 85's original electric antenna couple days ago when it quit retracting and the motor would continue to run even with the the ignition off.
Easy to do, raise the rear window and remove the plastic molding that goes around the rear latch. On the drivers side of the latch a connector where two plastic plug into, remove one of these and you have no power to the electric antenna.
Don't need a raised antenna for local FM.
Old Dec 26, 2010 | 12:26 PM
sailorsteve
rodj is correct, I would do the fuses first because it is easier, and if the problem is not found, look at the other circuits. Best to have a wiring diagram for this.
Old Dec 28, 2010 | 09:59 AM
michaelrobinson2618
Cruising
I charged the battery and tried the Milli amps test. the multimeter tells me 0 and doesn't move. I even tried the 12V DC as well and it stays at 12.78V I'm wondering if the battery is going bad after dieing so many times now. I bought a new starter hoping that that may be the problem I'm putting it on today. I was thinking it might have been the antenna, so i replaced it with one from eBay and it still doesn't work. I will probably just unplug it anyways to make sure. I'm thinking that it might be the starter. Is it possible for the solenoid to stick and constantly draw battery power? cause even after charging the battery the car wont start anymore. Unless its because the battery has gone bad. I don't know its a tricky one lol. I really appreciate everyone's help its just getting me one step closer to fixing this problem thanks.
Old Dec 28, 2010 | 10:04 AM
sailorsteve
I would have a load test done on the battery. This will tell you if it is failing. This is a simple test that takes only a minute and most stores that sell batteries will do it, no charge (no pun intended).
Old Dec 28, 2010 | 10:07 AM
michaelrobinson2618
Cruising
ok thanks i will probably take it to advance today just to have it checked. If its bad ill get a new one. I have a warranty on it.
Old Dec 28, 2010 | 03:30 PM
sailorsteve
Even if the battery turns out to be weak, there may still be an underlying problem causing a drain, not yet discovered. It wouldn't hurt to repeat the current draw test with the milliammeter with the replacement battery, if you wind up replacing it.
Old Dec 29, 2010 | 10:10 AM
michaelrobinson2618
Cruising
I replaced the starter and it started right up. Hopefully it was my problem. I'm on day 2 now without any problems so far.
To 1984 Corvette Wiring problem
