water pump leak
Old Dec 23, 2010 | 01:52 PM
Nanook71's Avatar
Nanook71
Default water pump leak
my (LT1) water pump is leaking from the front cover. is this a quick fix? (gasket) or sign of worse things to come (water pump going bad) Anyone else had this problem?
Old Dec 23, 2010 | 02:53 PM
STL94LT1's Avatar
STL94LT1
The front cover uses a large O-ring type of gasket, but I've yet to see one leak. Are you sure that is the source of your leak and not the weep hole?
Old Dec 23, 2010 | 03:07 PM
rinosaur's Avatar
rinosaur
Isn't that the same thing? front cover and weephole?
Old Dec 23, 2010 | 03:13 PM
STL94LT1's Avatar
STL94LT1
No, the weep hole is on the lower side.
Old Dec 23, 2010 | 03:19 PM
dogfish246's Avatar
dogfish246
Check this out...
Old Dec 23, 2010 | 04:41 PM
rinosaur's Avatar
rinosaur
Oh wow I never checked that for leaking when I reinstalled my WP. Whats the purpose of it?
Old Dec 23, 2010 | 07:00 PM
93Rubie's Avatar
93Rubie
I replace some gaskets on a 94 where the pump meets the cooling passages in the block, it was leaking there. 4 bucks a piece and my time, good as new.
Old Dec 23, 2010 | 09:53 PM
94vettelover2's Avatar
94vettelover2
Originally Posted by dogfish246
Check this out...
Man those later model c4 vettes look sweet!Oh wait,I own oneMan I miss mine as its still in storage.I wonder why I make these monthy payments when I'm not able to drive it,then spring rolls around & its all worth it.Sorry for the rant.All vettes look sweet
Old Dec 23, 2010 | 11:06 PM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
Rant as much as you want.
With the snow you've already got it'll be June till it's gone.
Old Dec 23, 2010 | 11:32 PM
94vettelover2
Its snowing now
Old Dec 23, 2010 | 11:49 PM
92WhiteVetteGuy's Avatar
92WhiteVetteGuy
Hi,
A leak on the top of the WP could also be from leakage/seepage around the top boltholes.
To water pump leak
