Lifter Preload
Old Dec 24, 2010 | 12:18 PM
C409's Avatar
C409
Default Lifter Preload
........... Do changes in lifter preload effectively change pushrod length as seen at the rocker tip / valve stem ?? ......... As a for instance ... if I change from the factory recommended one full turn down ( approx .060" preload ) to one quarter turn down ( approx .015" preload ) ... have I lengthened the pushrod by .045" at the rocker ?? ...............
Old Dec 25, 2010 | 09:15 AM
C409's Avatar
C409
Originally Posted by oldalaskaman
if I read this right , you've shortened the push rod 'felt' length, your not pushing the valve as far into the cumbustion chamber, actually reducing duration, they may become noisy also. there's alot of variables that you havent mentioned.
............. HUH ? ................. I'm just referring to rocker adjustment and its dynamic "effect" on pushrod length ........... there's no change in lift or duration ... and , the amount of preload should have no bearing on the amount of noise ... at least as long as there is SOME preload .......
Old Dec 25, 2010 | 01:41 PM
C409's Avatar
C409
.......... Thanks .................
Old Dec 25, 2010 | 04:50 PM
Crepitus's Avatar
Crepitus
assuming that you are running stud rockers not shaft; As you turn the rocker adjusting nut tighter to sink the plunger into the lifter the rocker fulcrum is moving as well, changing the geometry.
To Lifter Preload
