Sound-Reduction Insulation
Old Apr 8, 2002 | 12:21 PM
White Lightning's Avatar
White Lightning
Default Sound-Reduction Insulation
I recently had a mechanic replace the heater core in my 89, and during that process he removed and threw away the sound-reducing insulation that normally is behind the "breadbox" and under the dashpad.
Can anyone tell me where to get more of that insulation or a reasonable substitute? Without that insulation, I'm getting some squeeking and rattling that wasn't there before.
Thanks in advance,
-WL
Old Apr 8, 2002 | 09:40 PM
bogus's Avatar
bogus
Default Re: Sound-Reduction Insulation (White Lightning)
try your local stereo shop... they have stuff called dynomat that comes in numerious styles and weights.
Old Apr 8, 2002 | 09:56 PM
STL94LT1's Avatar
STL94LT1
Default Re: Sound-Reduction Insulation (bogus)
I used this in my truck, works great.
Old Apr 9, 2002 | 12:06 PM
tdock's Avatar
tdock
The dynamat is a great product but much thinner than the stock stuff, I think what is in there from the factory looks more like carpet padding. Depending on where it was installed, you might want to hit the local carpet store and get a small piece of padding.
Old Apr 9, 2002 | 12:55 PM
White Lightning
Default Re: Sound-Reduction Insulation (tdock)
Thanks, everyone.
-WL
Old Apr 9, 2002 | 02:48 PM
_Nomad_'s Avatar
_Nomad_
From: Frankenstein never scared me. Marsupials do, because they're fassst…and they DART, THAT'S crazy!
I agree, do not get Dynomat for that. You need about 1/4" to 12" carpet padding "foam". Dynomat is used for different applications.
Old Apr 9, 2002 | 05:38 PM
damionvoss's Avatar
damionvoss
Default Re: Sound-Reduction Insulation (The^Nomad)
You could buy ice & water shield from your local hardware store...the stuff is almost identical to Dynamat, and much less expensive. I have used it in several cars/trucks.
To Sound-Reduction Insulation
