adding oil
Old Apr 8, 2002 | 01:01 PM
rob_805's Avatar
rob_805
4th Gear
Default adding oil
Just bought a 85 Corvette. How do I add oil? I can't find the cap.
Old Apr 8, 2002 | 01:41 PM
Bob86ZZ4's Avatar
Bob86ZZ4
Default Re: adding oil (rob_805)
Wow, there should be one on the valve cover. Maybe somebody put some aftermarket valve covers on your engine. If so you need to pull out the pcv valve stuck into the cover and use a funnel to add it there. I have to add to mine through the breather hole since I have Edelbrock covers.
