6-speed shifter boot question
Old Dec 27, 2010 | 01:58 PM
dlt4's Avatar
dlt4
Default 6-speed shifter boot question
I pulled the console trim plate out of my '96 to do some touch-up painting on it and also because the shifter boot was flopping around. I know now why the boot was loose since none of the four points where the boot connects to the trim plate were still connected.
It looks like the plastic stubs just broke off inside all four of the metal clasps attached with the screws. Are the metal clasps just supposed to hold the boot in place by gripping the plastic posts?
Since a new console trim plate is $150 I don't want to replace it if I can avoid it. Perhaps glueing them might hold, at least for a while.
Any suggestions? Thanks.
PS: is the paint on the console just a regular semi-gloss paint?
Old Dec 27, 2010 | 03:59 PM
VetteMed's Avatar
VetteMed
JB-Weld the plastic posts back into place on the underside of the console. For the amount of torque that those little posts need to withstand, it should hold up fine.
Old Dec 27, 2010 | 05:42 PM
dlt4's Avatar
dlt4
Unfortunately the posts are broke off up inside the metal clasps.
I applied some construction glue this afternoon that I'm letting set until tomorrow, although I don't hold out a lot of hope for that solution.
Old Dec 27, 2010 | 06:20 PM
VetteMed's Avatar
VetteMed
Mine did the same thing - it's OK. Just JB weld them as-is, and when set, you should still be OK. At least I was in my '94.
Old Dec 27, 2010 | 06:52 PM
rinosaur's Avatar
rinosaur
I just installed a new boot a few days ago. I used 3M weatherstripping glue but I figure any strong glue would hold, the glue will definately suffice, you don't need the screws, make sure you glue all 4 sides.
Old Dec 27, 2010 | 06:59 PM
dlt4's Avatar
dlt4
Hmmm, OK, I admit it. I don't know what "JB weld" is
Old Dec 27, 2010 | 07:17 PM
Rocket-J's Avatar
Rocket-J
Just ask for "JB Weld" at any Hardware store. It is very common. Any two part epoxy glue will work too.
Old Dec 27, 2010 | 07:53 PM
dlt4's Avatar
dlt4
Thanks for the info.
Old Dec 27, 2010 | 07:54 PM
rinosaur's Avatar
rinosaur
Oh and make sure you install the boot on the metal bracket the correct way!! I did mine wrong but luckily I was able to pull the boot off (with a lot of force) and do it the correct way. I guess weatherstripping glue helped me in this sense, epoxy would force me to rip it out lol.
Old Dec 27, 2010 | 08:16 PM
dlt4's Avatar
dlt4
Not that I would do anything like that (), but on my '96 the posts are spaced differently at each end to prevent that.
But thanks for the tip!
Old Dec 28, 2010 | 04:12 AM
skyzzics's Avatar
skyzzics
Default Screw it.
I had to do this.Three fasteners were totally crushed with no way to fix. The third one was passable at least for a while. I will do the last one when it fails and it will make it all even.
I know this is not the best solution but it works for me.
Old Dec 30, 2010 | 09:51 AM
larry93lt1's Avatar
larry93lt1
From: Gaithersburg MD A member since 2007 but then the computer crashed and then the car crash loss of memory X 2
JB Quik worked on my front speaker enclosures and 2 posts on the shifter boot after the "Big Footed" Previous owner trashed both of them.
Hey Andrew Happy New Year to all down the in the Sunshine, but not heat, State.
Old Feb 3, 2013 | 01:37 PM
Sunnyflorida's Avatar
Sunnyflorida
JB Weld is amazing stuff.
I have a 4x4 Case Backhoe/Loader (old) the previous owner allowed the main cup barring on the front wheel hub at the king pin to go bad and drove it until the round 2 inch barring receiver machined into the bottom of the axel was shaped like an egg. We got a new two piece cone-shaped barring and JB Welded the female piece of the barring into the oval hole that was left (took two packages to fill the space). This barring holds the entire weight of the front of the loader (and a bucket full of dirt) and has side pressure when you turn the wheel or go over un-even ground.
Holds.
That JB Weld is as strong as the iron of the axel. I swear by it.
Old Feb 3, 2013 | 04:30 PM
octaneforce's Avatar
octaneforce
that looks great! i need to do the same on mine. is that a custom boot?
Old Feb 3, 2013 | 04:37 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
This thread is over 2 years old.
skyzzics last posted in Nov. 2011.
To 6-speed shifter boot question
