GS Hash Marks, exact dimensions?
Apr 8, 2002 | 08:50 PM
Anyone have the exact numbers? I'm gonna get them painted on my car, but the paint guy needs the dimensions. I'm thinking 11"x4"?
Apr 8, 2002 | 10:44 PM
Re: GS Hash Marks, exact dimensions? (TIMSPEED)
I don't have the dimensions for you, but don't forget to get the correct spacing and angle. Good luck. :cheers:
BTW, if you don't get an answer, the next time I have the cover off, I'll check for you. Right now it's dark and the covers wet. (sorry) I'm not sure I have anything around here to check the angle. Have to check my daughters school supplies. :D
[Modified by R94 LT 1, 8:46 PM 4/8/2002]
Apr 8, 2002 | 10:56 PM
Did you email me for the measurements? Someone did and I am not sure who it was. If it was you, i am sorry that I couldn't get the exact measurements for you. To do that I would need to get angles and everything. If you are not the person that sent me the email, then you might be able to get the info off of here. You would have to make mock ups of course out of paper or something.
http://www.vettextc.net/hash_marks.htm
[Modified by OrangeC4, 2:57 AM 4/9/2002]
Apr 8, 2002 | 11:14 PM
Since you want to get them painted on, I would suggest finding someone that has a GS and can trace them for you and either mail that to you or fax it to you. That way you can give them exactly what you need.
Apr 8, 2002 | 11:30 PM
Re: GS Hash Marks, exact dimensions? (OrangeC4)
hmmmmmm, that sounds like an idea. :yesnod:
Apr 8, 2002 | 11:31 PM
Well, the guy that's painting my car used to have a GS, SO...but he never really measured the strips.
Apr 8, 2002 | 11:56 PM
hey buddy, I gotcha.
2.75" wide
1" apart
9" long on one side, 9.5" on the other. (because of the angle to make them flat at the top.
from the peak at the corner of the hood, where it goes from the side to top, to the "top right" of the hash marks is 37"
let me know if you need anything else
Apr 9, 2002 | 12:04 AM
Tim,
You might want to check with your local dealer. The factory decals come with a template for placement and you could trace them off of it.
GM part #10279781
Dave
Apr 9, 2002 | 12:07 AM
St. Jude Donor '05-'06
Re: GS Hash Marks, exact dimensions? (Kale)
Got a ruler...
The First Stripe
Top: 5 3/8" Bottom: 3 5/8"
Left and right sides are 8 3/4"
With a very light curve...
Spacing Between The Stripes
Top: 1 3/16" Bottom: 1 1/8"
The Second Stripe
Top: 3 1/5" Bottom: 4"
Left: 9" Right 9 1/2"
Little more curve then the second stripe.
Hope this helps
[Modified by Coupe89, 4:21 AM 4/9/2002]
Apr 9, 2002 | 01:10 AM
Re: GS Hash Marks, exact dimensions? (Coupe89)
:cool: You found it! :cool: :cheers: :seeya
Apr 9, 2002 | 09:29 AM
Quote:
Got a ruler...
The First Stripe
The Second Stripe
Hope this helps
Now that I'm awake, or maybe just noticed, that top lenght on the first stripe seems to be a little long? :confused: :rolleyes:
Apr 9, 2002 | 10:27 AM
Re: GS Hash Marks, exact dimensions? (R94 LT 1)
The first stripe is smaller
Apr 9, 2002 | 09:31 PM
Sorry for the wrong dimensions. :crazy:
The time change must have affected me :crazy:
The First Stripe
Top: 3 1/2" Bottom: 3 1/2"
Left side: 8 3/4" Right Side:8 7/8"
Top: 1 3/16" Bottom: 1 1/4"
The Second Stripe
Top: 3 1/2" Bottom: 4"
Left: 8 7/8" Right 9 5/8"
