erratic cooling fan
Old Apr 8, 2002 | 09:20 PM
84FromHell's Avatar
84FromHell
Default erratic cooling fan
My fan never seems to come on at the same temperature twice. Since I bought the car it's been coming on around 210*, sometimes 215* and yesterday it went up to 230* before it kicked on.
So my question is this - from what I understand the fan is controlled by the computer. How can I tell if the temp sensor is the problem or if it's the computer causing the problem?
Also I'm thinking about adding an auxilary fan. I hate to spend $200 on a electric fan when I can go to a salvage yard and probably get one for around $20. Anyone have any first hand knowledge of slapping a generic fan with a manual switch on a Corvette?
Old Apr 9, 2002 | 02:04 AM
vettemech85's Avatar
vettemech85
Default Re: erratic cooling fan (84FromHell)
On my Trans Am I just grounded the fan temp sensor with a toggle switch in between. It was a lousy quick fix when I was in a bind. On the Vette I replaced the fan temp switch with one from a Pontiac of some sort that had the same threads and plug but it turns on at, 216 I think? I went to a parts store that had pictures of fan temp switches and said what temp it came on. So I used the Pontiac? one. Works great.
Old Apr 9, 2002 | 02:15 AM
merrick's Avatar
merrick
The sensor is a variable resistor. Install a new one ($15) and see what it does.
Old Apr 9, 2002 | 10:58 AM
84FromHell's Avatar
84FromHell
thanks for the replies!
a new sensor is at the top of my shopping list :chevy :chevy :chevy
Old Apr 9, 2002 | 11:18 AM
JonM's Avatar
JonM
You may want to look into one that comes on at 200 and off at 180..(temp switch)
Old Apr 9, 2002 | 01:21 PM
The Gooch's Avatar
The Gooch
St. Jude Donor '06-'07-'08-'09-'10
When mine started that, It turned out to be the relay.
Old Apr 10, 2002 | 01:04 AM
84FromHell's Avatar
84FromHell
JonM that sounds like what I'm looking for. Do you have a part # or an application so I don't have to spend $50 at Eckler's for a $15 sensor?
I checked with a parts guy today, he looked through his book and really couldn't help me much
Old Apr 10, 2002 | 08:56 AM
JonM's Avatar
JonM
MID AMERICA has them for 12.95...#609-106...If you look in the catalog #142C its on page 4-76 Fits 84-91
Old Apr 10, 2002 | 11:03 AM
84FromHell's Avatar
84FromHell
Old Apr 10, 2002 | 11:05 AM
84FromHell's Avatar
84FromHell
Thanks Jon! :cheers:
Old Apr 10, 2002 | 02:17 PM
vettes's Avatar
vettes
I have this same problem w/ my fans running crazy.Trying to find out what is causing this the relays or fan switch.I have 200* fan switch w/ harness for both fans to go on the same time.It worked great for 2 yrs and mine is a 92.
To erratic cooling fan
