Mobil1 0w30?
Old Apr 8, 2002 | 10:57 PM
IcemanZ06's Avatar
IcemanZ06
Default Mobil1 0w30?
What exactly is this oil used for? I saw it at the parts shop tonight next to the 5w30.
Old Apr 8, 2002 | 11:00 PM
BobMachus's Avatar
BobMachus
Default Re: Mobil1 0w30? (IcemanZ06)
Just a slightly thicker cold viscosity oil. Some people who live in hot climates will use an oil like that, or in an older/higher mileage engine to try and control leakage a bit.
Old Apr 8, 2002 | 11:04 PM
IcemanZ06's Avatar
IcemanZ06
Default Re: Mobil1 0w30? (BobMachus)
What is better for a southern car (SC). 5w30 or 10w30?
Old Apr 8, 2002 | 11:24 PM
Dan Parker '96's Avatar
Dan Parker '96
Stick with what the manufacturer recommends. You can't improve on it.
Old Apr 9, 2002 | 12:14 AM
vader86's Avatar
vader86
10w30 all year round will work if we have a mild winter, but i run 5w30 in winter just in case we get some really cold weather
If i was in FL id run 10w30 or straight 30 weight year round
Old Apr 9, 2002 | 04:33 AM
merrick's Avatar
merrick
Bob has it backwards. 0w/30 is thinner than 5w/30. You can use it if you want, but your oil pressure will be lower. You make more HP with a thinner oil.
Old Apr 9, 2002 | 07:09 AM
Shylor's Avatar
Shylor
0w30 is actually the weight oil used in the Honda Insight Hybrid.
Old Apr 9, 2002 | 09:35 AM
85 Dave's Avatar
85 Dave
0w30 is used for extremely cold temperatures. Once the oil is warmed up to normal operating temp, it should have the same viscosity as the 5w30 or 10w30. The first number represents the viscosity at a certain cold temperature, and the second number represents viscosity at a certain hot temperature. At the cold temperature, a 0w30 has the viscosity of a 0 weight oil. A 5w30 has the viscosity of a 5 weight oil, and so on. At the hot temperature, they all have the viscosity of a 30 weight oil. The lower cold temp viscosity (i.e. 0w30) is generally better for reducing wear upon startup.
C4SMAJ's Avatar
C4SMAJ
Default Re: Mobil1 0w30? (Shylor)
Ford is also using it in some of thier new cars.....i.e. the Focus.....the Ford guy told me it helps gas mileage.....every lit bit helps I guess......
Old Apr 9, 2002 | 12:27 PM
93 ragtop's Avatar
93 ragtop
Default Re: Mobil1 0w30? (larryf)
Have you seen the new 5-20 that ford is using? So far they are the only suppliers of it as well. (that meets their specs) I guess it is one of Fords better ideas :rolleyes:
Old Apr 9, 2002 | 01:59 PM
85 Dave's Avatar
85 Dave
Default Re: Mobil1 0w30? (Red 86 4+3)
Actually, several oil companies now have the 5w20 oil that meets or exceeds Fords requirements. The lighter oil improves fuel economy. What's wrong with that? BTW, the Ford oil is manufactured by Conoco, and its a hydro-cracked oil. That's the same process that Castrol uses to make their "synthetic" oil. But the Ford oil is about half the cost, and they claim it to be "semi-synthetic". From what I've heard, its the best bang for the buck right now. But I doubt our Vettes will be able to use an oil this light.
Old Apr 9, 2002 | 03:33 PM
James94LT1's Avatar
James94LT1
Default Re: Mobil1 0w30? (merrick)
I read one time in super chevy I think that on a dyno a 350 made the most hp with a 20-50w oil. I've ran 15w-50 in my vette since I got it, I just recently went to the 5-30 again to go with the lower weight, more power theory. I don't know though. I think I may go back to the 15-50 mobil1?!?!
0 weight just sounds bad to me.
Old Apr 9, 2002 | 03:41 PM
93 ragtop's Avatar
93 ragtop
Default Re: Mobil1 0w30? (85 Dave)
Not according to the Pat Goss show. There are other manufactures of 5-20 such as pennzoil but they are not reconized by ford at meeting their specs. As far as what is wrong with it, I do question the use of a 20 weight oil in a vehicle in a hot climate. Is it being done just to meet fuel milage requirements?
Old Apr 9, 2002 | 04:26 PM
ittlfly's Avatar
ittlfly
When I lived in snow country, I used the 0-30wt Mobile One. I felt it made it a little easier on the engine on start ups in the cold months. I did however switch back to 5-30wt as the weather warmed up.
Old Apr 10, 2002 | 11:05 AM
85 Dave's Avatar
85 Dave
Actually, several oil companies now have the 5w20 oil that meets or exceeds Fords requirements. ...
Interesting. My information came from the back of the motor oil bottles. It said that it meets or exceeds the Ford standards. Maybe they lied...
To Mobil1 0w30?
