Dump ZF6?
Old Jan 5, 2011 | 12:29 PM
jwt1603's Avatar
jwt1603
Originally Posted by helphos
This thread is INTERESTING! Thanks for the great dialog!
Would you have pics or other advice to identify where the hinged cover plates are for the C-Beam??
I have a ZF with a bad 2nd gear, and bought a used ZF to replace it. I'll need to attack those C-Beam bolts someday soon.
Thanks!
PS is it a big deal (and expensive?) to change rear end gears?
If it's a street car I probably wouldn't recommend the hatches due to noise and whatnot. You probably don't want to cut up your carpet for something a street car shouldn't have to do very often. For a track car they're great. I call still send you a couple of pics if you want.
The rear gear isn't expensive if you have the tools and the know-how about setting the depth on the pinion gear. I do a lot of work on the car myself but gears I send out.
Old Jan 6, 2011 | 09:41 AM
LD85's Avatar
LD85
TKO weighs @ 90 lbs
I think a better solution is a mid engine support, although I have not seen this done on a C4
Old Jan 6, 2011 | 11:58 AM
helphos's Avatar
helphos
Default ZF transmission
From JWT1603: "If it's a street car I probably wouldn't recommend the hatches due to noise and whatnot. You probably don't want to cut up your carpet for something a street car shouldn't have to do very often. For a track car they're great. I call still send you a couple of pics if you want."
Thanks for the info. I thought maybe the hatch might be hidden by the cup holder or the armrest, but I know what you mean. My car is a convertible so it's noisy enough as it is without cutting a hatch for a (hopefully) one time use.
As always, I appreciate the helpfulness of the people on this forum. This is where I learned that my 2nd gear problems were probably caused by my leaky slave cylinder, which was probably caused by some low paid worker installing the seals backwards on the rebuilt cylinder!!
Paul
Old Jan 8, 2011 | 09:25 AM
TJM's Avatar
TJM
Originally Posted by jwt1603
Does anyone make a kit to dump the ZF6 and the stupid C-beam and put a regular 4 or 5 speed trans in a C4?
I'm so tired of messing with the C-beam and the trans weighs a ton compared to most transmissions. And I don't need 6 gears for auto cross and track days.
There was a kit I looked at [ can't find the bloody thing now?] made for the T5 to bolt in, $125.00, but it used the C beam?
Don't take this wrong, but I see Camaro racers spending $2,000 to essentially set up their cars with bars that are essentially doing what C beam seems to do?
Granted the ZF weighs a ton but the steel need to support everything might well add the weight back into the car you save on the light weight transmission?
So, other than ease of removing broken stuff, what's the advantage?
TJM
