new member tech?
Old Jan 4, 2011 | 05:11 PM
92greatwhite's Avatar
92greatwhite
1st Gear
Default new member tech?
I am not new to engine performance i am however new to lt1 engines I have built several high performance gen 1 sbc but have only done regular maintenace on my 92 Corvette i have had the car for some time and am getting a little bored with it i drive it at most 3-4 times per year it has about 140,000 miles on it i have considered building a gen1 engine and just running carburation but i have been told by a buddy of mine that the lt1's have a lot of potential i would like to put about 450 hp to the wheel naturaly asperated how strong is the factory block and crank and can you port a stock intake to using after market heads to build this kind of power or would you have to run a tunnel ram setup any additional info would help or links to websites or other thraeds to read about building lt1 engines would greatly be appreciated.
thanks,
Will
Old Jan 4, 2011 | 10:05 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
bore & stroke (383 or 396)
I forget the after market heads - do a search (I think it was the AFR)
Cam to match, port the heck out of the intake, TB to match
That should get you there
