bad injectors?
Old Jan 4, 2011 | 05:27 PM
tehcarguy's Avatar
tehcarguy
Default bad injectors?
My 86 has been sputtering when a load is put on the engine, like accelerating/ going up a hill etc. but it idles perfectly. It's like a miss, but on all cylinders and randomly. I have new cap, rotor, coil, plugs, fuel pump, and fuel filter. The injectors are original, so I they might be causing the problems. I'll do a fp test in a min and check all the plugs when it cools down. You guys have any idea what might be wrong?
Old Jan 4, 2011 | 05:59 PM
tehcarguy's Avatar
tehcarguy
Fuel pressure is good at idle and rev...but now I smell like gas.
Old Jan 4, 2011 | 06:22 PM
Jimbo 89's Avatar
Jimbo 89
With my 89, I noticed it ran fine when cold, (in open loop), but when it warmed up is when it seemed to skip. This seems to be the norm.
New fuel injectors made the diff for me. If u have the stock Multecs, the ethanol in today's gas eats them up, so don't put those back in.
What I did was call Jon at fuelinjectorconnection.com like many others have done. See sticky on fuel injectors at top of page C4 Tech/Perf.
Old Jan 4, 2011 | 06:28 PM
tehcarguy's Avatar
tehcarguy
thanks Jimbo. Mine does this whether its warm or cold. I'm pretty certain it's the injectors now. I will be going to FIC in the future though.
Old Jan 4, 2011 | 06:38 PM
Muffin's Avatar
Muffin
Good move on the injectors. In the meanwhile check your plug wires. Are any arcing when under load?
Old Jan 4, 2011 | 08:06 PM
tehcarguy's Avatar
tehcarguy
I checked all the wires, and the insulation on all of them is ok. could they still be arcing even if they look fine?
Old Jan 4, 2011 | 10:43 PM
Muffin's Avatar
Muffin
Yes, especially under load. Best and oldest check I know of is after dark , have someone apply all the brakes, start the engine, apply more breaks, put in gear rev engine until it is under a slight load, watch engine. If you have cracks in the insulation you will see sparks jumping to ground. Obviously this is somewhat dangerous so be careful. Did I mention applying the brakes and not overreving?
Old Jan 4, 2011 | 11:03 PM
tehcarguy's Avatar
tehcarguy
My dad taught me that trick with his old truck that had an HEI ignition. Sparks would go everywhere.
Old Jan 5, 2011 | 01:21 PM
Siveck's Avatar
Siveck
This very well could be an injector issue. However, eliminate the EGR as a culprit first. Pull the vacuum hose from the EGR and plug the open vacuum line temporarily. Go for a drive and see if the condition still exists. You can also ohm test the injectors for consistent readings and that will sometimes be an indicator of bad injectors.
Old Jan 5, 2011 | 01:36 PM
redjetty's Avatar
redjetty
my 89 was doing the same thing with original injectors in them,,, I replaced mine just this week and boy what a difference,,,, first thing I did was ohm out my injectors, and I found the bad injector only ohming out at 2,,,,, as someone mentioned,, jon hooked me up at FIC,,,, good luck,, rj
Old Jan 5, 2011 | 02:13 PM
383vett's Avatar
383vett
Might want to swap out the ignition module in the distributor. Less expensive and easy to do compared to injectors. Yours is 25 years old now. Sometimes they can cause gremlins like you're describing. Worth a try.
Old Jan 5, 2011 | 03:39 PM
surfer93's Avatar
surfer93
You could get a factory service manual, Multi meter and test, the FSM gives you step by step instructions and does this based on given scenerio's.
Old Jan 5, 2011 | 07:12 PM
Ricks94vette's Avatar
Ricks94vette
Mailed mine to this place 5 1/2 years ago and haven't had a problem yet. Great place, reliable and only $19 for each injector rebuild, that is if its rebuildable.
If you decide to mail your injectors to them but the low cost insurance from the post office.
Old Jan 5, 2011 | 08:43 PM
aklim's Avatar
aklim
Absolutely. Run the car and set the RPMs up with either a brick at the pedal or something. Spray a fine water mist around, not at, the wires and see what happens. Obviously it has to be in total darkness to work.
aklim's Avatar
aklim
Whatever the thing, just send it out for a cleaning and testing. It is due anyways.
Old Jan 6, 2011 | 08:34 PM
tehcarguy's Avatar
tehcarguy
I did ohm test the injectors all were at 16 and cylinders 5 and 8 were at 15.8.
Old Jan 6, 2011 | 08:35 PM
tehcarguy's Avatar
tehcarguy
Is there any way to test that? I don't want to just throw parts at it, a new ICM is around $50. I know I need the injectors, so that's why I'm trying those first.
To bad injectors?
Old Jan 6, 2011 | 09:25 PM
aklim's Avatar
aklim
Ohm test is meaningless when it comes to determining whether the injector is spraying right or not.
Old Jan 6, 2011 | 09:34 PM
tehcarguy's Avatar
tehcarguy
I know that, but it's an easy test so I did that to humor myself.
Old Jan 6, 2011 | 09:38 PM
aklim's Avatar
aklim
People have mentioned that the ICM has been tested to be good but replacing it cured problems. Mine too. Get a good Delco one and keep it as a spare.
