check code .... fan started
Old Apr 9, 2002 | 02:32 PM
Frank92's Avatar
Frank92
Default check code .... fan started
the fan started when i checked the codes (jumper a an b). is that normal ?
frank
Old Apr 9, 2002 | 03:05 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
Default Re: check code .... fan started (Frank92)
that's normal behavior! :yesnod:
Old Apr 9, 2002 | 05:17 PM
Frank92's Avatar
Frank92
Default Re: check code .... fan started (Marcho Polo)
thanks !
thinks thats the only thing thats normal with my vette.
frank
Old Apr 9, 2002 | 06:13 PM
NoWorries's Avatar
NoWorries
As Craig said, its normal. Consensus is that it is to check the operation of the fan(s).
Old Apr 9, 2002 | 06:21 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Normal; with the paper clip across A&B and ignition On the ECM is in "diagnostic mode".
In addition, if you start the engine and run the car the SES will flash. The duration of the On vs Off period indicates rich or lean. In closed loop mode at idle or under very light load the On/Off ratio should be about equal, indicating 14.7:1. This can be useful to detect a failed O2 sensor or related trouble.
Old Apr 10, 2002 | 06:24 AM
Frank92's Avatar
Frank92
Default Re: check code .... fan started (65Z01)
I´ll try taht today.
Thanks Frank
To check code .... fan started
