bad cat.??
Old Apr 9, 2002 | 03:57 PM
flubuyu2's Avatar
flubuyu2
Default bad cat.??
I posted preves. about the problems,runs good till I push the gas !she hits about 3500-4000 rpms and dies will not restart till she is completely cooled down...my question is this what will a bad cat do? what kinda problems have you guys experienced ?I do have a rattle in the drivers side cat for sure could this be it??
Old Apr 9, 2002 | 05:51 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: bad cat.?? (flubuyu2)
You can have a pressure check run but since it's rattling, just change it out.
Old Apr 9, 2002 | 06:21 PM
flubuyu2's Avatar
flubuyu2
Default Re: bad cat.?? (65Z01)
what kind of things will the car be doing if the cat. is bad ??do you think it will cause my problems???help me man help me !!Thanx
Old Apr 9, 2002 | 06:23 PM
65Z01's Avatar
65Z01
A partially clogged cat can cause loss of power, fuel efficiency and cause excessive heat that carn burn the carpet or padding.
BBA's Avatar
BBA
A completely melted cat can do that.
To bad cat.??
