Remove Oil Sender(Switch)
Old Jan 10, 2011 | 03:25 PM
donmye's Avatar
donmye
Default Remove Oil Sender(Switch)
How in the world do i remove the bottom oil sender back by the distributer. Thier is 2 one set all most straight up the other one is sideways. I cant find any tool to get this off. Please HELP Don
Old Jan 10, 2011 | 04:34 PM
steven mack's Avatar
steven mack
You use an open end wrench or the box end side.The two sending units are different sizes.You may have to turn the distributer or remove it to get enough room too use the wrench.The piece they screw into can be removed with the right size socket.
Old Jan 10, 2011 | 05:08 PM
rodj's Avatar
rodj
Originally Posted by steven mack
remove it
Much less frustrating to take dist out
Old Jan 11, 2011 | 08:05 AM
twotone84vette's Avatar
twotone84vette
I took out the windshield wiper motor.
Old Jan 11, 2011 | 09:13 AM
donmye's Avatar
donmye
Can anyone tell me the size of the wrench it takes. Don
Old Jan 11, 2011 | 09:15 AM
ddahlgren's Avatar
ddahlgren
I ended up useing a pair of channel lock plies when the wrench would not get it out and was lucky. New one went in rather easy with the wrench and some teflon tape. My thought was the sensor is no good so can not hurt it and if the pliers don't work will start pulling other things to get a good bite with a wrench. Yes it sounds crude but saved a ton of time as a first try to get it out of there.
Dave
Old Jan 11, 2011 | 09:26 AM
Muffin's Avatar
Muffin
Don, I think that is a special socket. I am sure a 12 point will work but it is a sloppy fit. FYI the design and placement of those two sensors was done by the same guy who did the heater core and rear tail lights.
Pulling the distributor is not a big deal if you stay away from the starter. Also those are very fine threads you are working with, cross thread is very easy so caution is advised.
Old Jan 11, 2011 | 09:32 AM
ddahlgren's Avatar
ddahlgren
I think they got some help from the guy that put all the relays behind the dash... Why does changing a relay have to involve removeing dash panels? If I had bought an earlier car i would have pulled about 50% of the wiring out and put things where you can actually get to them.
Old Jan 11, 2011 | 03:11 PM
j-wireman's Avatar
j-wireman
I think it has to do with ease/speed of assembly at the factory--future owners and/or technicians be damned.
Old Jan 12, 2011 | 08:59 AM
Bubba91's Avatar
Bubba91
Dave
I also used channel lock pliers, after I took the dist cap off. Couldn't turn it hardly at all, but after many little turns it came off. I put in a new sender and switch just to be on the safe side. I got a socket on the top one.
Old Jan 12, 2011 | 09:05 AM
ddahlgren's Avatar
ddahlgren
My thought is it is pretty hard to break something that is broken already as long as you don't burn any bridges by rounding off wrench flats you always have a backup plan.
Dave
To Remove Oil Sender(Switch)
