1989 Instrument cluster
Old Jan 11, 2011 | 07:55 PM
JinksEll's Avatar
JinksEll
Cruising
Default 1989 Instrument cluster
In the center of the cluster are two smaller displays. Left side is oil pressure and right side is battery voltage. Everything working as should be, then I noticed the right side of the cluster is dim. Doesn't matter if I turn on the lights or just parking lights it stay the same. Any Ideas?
Old Jan 11, 2011 | 08:40 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Have you checked the light bulbs behind the panel?
Old Jan 11, 2011 | 09:05 PM
JinksEll's Avatar
JinksEll
Cruising
No I haven't, this is my first Corvette and had no Idea where to start. I'll try that, thanks
Old Jan 11, 2011 | 09:16 PM
Black89Z51's Avatar
Black89Z51
I took mine out and replaced it with an autometer set. I will take a picture of the back of it tomorrow to show you what you're looking for.
Old Jan 11, 2011 | 09:22 PM
JinksEll's Avatar
JinksEll
Cruising
That will be great, thanks alot
Old Jan 11, 2011 | 10:06 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
http://www.batee.com/corvette/index.htm
Old Jan 12, 2011 | 10:33 PM
62panshovel's Avatar
62panshovel
On an 89 the bulbs can be removed without removing and disassembling the cluster. I removed mine to replace the bulbs anyway but the posts I observed prior to removal are correct on that fact.
To 1989 Instrument cluster
