87 vette need help
Old Jan 12, 2011 | 01:59 PM
neil burkhead's Avatar
neil burkhead
Cruising
Default 87 vette need help
I'm new to this need help with my 87 vette . Why when I press the brake down my digital temp light on my ac heat control panel goes off it also flickers a lot is this a relay. I also have no flashing turn signals on passenger side driver side works great but not on passenger side also the arrow above the steering wheel stays solid on bad side help
Old Jan 12, 2011 | 02:39 PM
oldalaskaman's Avatar
oldalaskaman
on the turns , check all your bulbs, probably have one or more burned out
Old Jan 12, 2011 | 05:34 PM
neil burkhead
Cruising
Thank u. My digital cluster also works fine with headlights off but when lights on only one side lights up
Old Jan 12, 2011 | 06:25 PM
redvetttes's Avatar
redvetttes
Short in the light sockets
Replace them
Solder the wires, don,t need any cop stops for lights
Old Jan 12, 2011 | 06:32 PM
neil burkhead
Cruising
Yeah we live in little town vettes draw enough attention from cops lol were does it need soldered
Old Jan 12, 2011 | 06:46 PM
neil burkhead
Cruising
Anyone got any ideals on why temp light goes off on climate control display when I press the brake
Old Jan 12, 2011 | 07:26 PM
redvetttes's Avatar
redvetttes
I solder all my connection ,then shrink tube
I hate butt splices
Old Jan 12, 2011 | 10:59 PM
Muffin's Avatar
Muffin
Faulty grounds can do strange things. Most times when I have an electrical bug I approach it through the ground circuits.
Old Jan 13, 2011 | 12:26 AM
phat87's Avatar
phat87
2021 C4 of the Year - Unmodified Finalist
Default clean terminals
I know it is a PITA to do but maybe it's time to clean the battery terminals. I just did both my vettes, one of them was quite corroded with white powder.
Also if you don't have the terminal bolts that extend out of the insulation surround this would be a good time to put new bolt in. (Just in case you ever have to jump it.)
I have no idea where the chassis end of the ground connects so I didn't do that but the battery end of things is relatively easier.
Old Jan 13, 2011 | 12:28 AM
jfb's Avatar
jfb
I don't know what you mean by, "temperature light". There are 3 lamps in the heating/ac temperature/blower control that provide back light. Two things can make the lamps turn off when you brake. Either the 12v turns off with the brake applied or the ground wire goes to 12v with the brake applied. On the temp control the 3 lamps get 12v power on the grey wire and there are two ground wires, both black. You need to measure all of these wires one at a time while you apply the brake and see if the 12v goes away or the ground wires rise in voltage (they should remain at zero volts). Then either ground the black wires with an added wire or trace the 12v circuit to find out where it shuts off when the brake is applied. It would help you a lot if you would buy the electrical diagnosis manual for your 87.
Old Jan 13, 2011 | 12:54 AM
oldalaskaman
on my 87 the left side was washed out during the day and there was enough light reflected from the bulbs that were workin in the dash at night to make it appear as though everything worked. Start replacing bulbs and you may find that cleaning plug connections,...etc, may cure your problem, it did on mine
Old Jan 14, 2011 | 12:57 PM
Chapindad's Avatar
Chapindad
1. Replace all the bulbs in the cluster, just be careful not to crush them in place. They are probably the originals. They are easy to replace except for getting 20 year old bulbs out.
2. The climate control unit is known for cold soldier joints. This is a PITA to fix.
3. Probably a bad ground. There is I believe a ground right next to the passenger headlight up front.
Old Jan 14, 2011 | 12:58 PM
Chapindad's Avatar
Chapindad
Oh Yeah! Welcome to the club!
To 87 vette need help
