Code 32
Old Apr 9, 2002 | 06:32 PM
Jarrydvette's Avatar
Jarrydvette
7th Gear
Default Code 32
I just had the egr valve and solenoid replaced, along with haveing the intake manifold taken off and completely cleaned.. I am still getting the sevice engine soon warning light With a code 32. Is there a way to reset the code besides unhooking the battery. Or could there be something eles to cause this code 32, beside what i have already had done to the car.. Any help or info would be greatly Appreciated..
Old Apr 9, 2002 | 06:47 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Code 32 (Jarrydvette)
You can pull the ECM fuse or use my method of opening the connection in the orange wire near the battery that powers the ECM.
If the code comes back verify that the vacuum lines involved are good; if so, replace the temp sensor in the EGR pipe.
Of course you could energize the EGR solenoid at idle and measure the voltage at the EGR temp sw. It should go from +5Vdc to 0Vdc when it heats up; this is the EGR feedback signal to the ECM.
Is the SES comming On at idle or after you're on the highway for a few minutes?
Old Apr 9, 2002 | 06:52 PM
Jarrydvette
7th Gear
Default Re: Code 32 (65Z01)
It comes on on the highway only..
Old Apr 9, 2002 | 06:59 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
what type of exhaust system do you have? Is it all stock? Are the pre-cats removed or the main cat? Do you have stock mufflers?
Old Apr 9, 2002 | 07:00 PM
Jarrydvette
7th Gear
Default Re: Code 32 (Marcho Polo)
Yes they are stock mufflers..
Old Apr 9, 2002 | 07:45 PM
vader86's Avatar
vader86
have you tightened your gas cap all the way until it clicks, that fixed mine
Old Apr 9, 2002 | 08:08 PM
65Z01's Avatar
65Z01
Since it doesn't come on at idle just after startup you know the EGR is not stuck open and the EGR temp sw is not closed (grounded).
First check all vacuum lines. If ok, run the test above to see if the temp sw closes when the EGR is forced open, allowing exhaust gasses to flow into the intake manifold.
Old Apr 9, 2002 | 08:32 PM
Jarrydvette
7th Gear
If i pull the fuse What should i do after that? check the codes while its out or replace it and then check the codes... ???????
Old Apr 9, 2002 | 09:04 PM
MagRed_04's Avatar
MagRed_04
Put it back in and check the codes... Mine gave me a 32 when me EGR temperature switch went bad.
JK
To Code 32
