Normal Fuel Lines?
Old Apr 9, 2002 | 08:05 PM
Dave95C4's Avatar
Dave95C4
Default Normal Fuel Lines?
I've recently found that one of the clips that holds the fuel lines to the frame of the car is broken, allowing one of the lines to bounce around. I've also noticed that it is slightly bent, as below...is this normal looking or has it been bent by force?
DW
[Modified by Dave95C4, 7:05 PM 4/9/2002]
Old Apr 9, 2002 | 08:26 PM
C4Cvette's Avatar
C4Cvette
Default Re: Normal Fuel Lines? (Dave95C4)
the clip on mine is broken the same. Someone put 2 tie-straps around both of them near the clip to hold them together. Mine also has the bend to it.
Old Apr 9, 2002 | 08:33 PM
Dave95C4's Avatar
Dave95C4
Default Re: Normal Fuel Lines? (C4Cvette)
Thanks man. I sent the local dealer an email with the pic and asked for a part # and price. I'll post it here once I find out, if you want. I've got mine tied together using garbage bag ties now...ghetto :U
DW
Old Apr 9, 2002 | 11:23 PM
C4Cvette's Avatar
C4Cvette
once you get the part, I dont think that you can get it on. You cant get it around the fitting on the fuel line. I also have one broken under the car that holds the fuel line.
To Normal Fuel Lines?
