1992 Corvette LT1 stalling issue
Old Jan 21, 2011 | 11:15 PM
TripleWhiteLT1's Avatar
TripleWhiteLT1
8th Gear
Originally Posted by Scotsman
I ordered the last one I installed from Summit Racing...was their "cheap" model, I think for about $250 or so. Has worked fine for a year now. I know a lot of guys only use the GM part, which would seem like a good thing to me if they didn't cost upwards of $600 each.........I have a family, and that much money would probably cause my wife to blow several gaskets, and thereby lower my chances at overall happiness.
Good luck man, opti replacement is kind of fun once you get past the cursing and into the drinking.
I lol'd at the last part of that. My thought is kinda that the factory GM part didn't even last 60k miles, so why put my money and faith into it again for that kind of price? If they had since redesigned it, and the unit available today was markedly improved over the original, that might be one thing, but I haven't read anything indicating that it is any better than what it came with.
Guess I'll look around some more. That said, I haven't messed with the car any more yet, so I still need to confirm that the Optispark is actually the problem, before I spend any money.
Thanks again!
Old Jan 22, 2011 | 12:21 AM
desertmike1's Avatar
desertmike1
Are there any signs of the water pump leaking anti-freeze on top of the Opti?
Did you do any detailing of the engine compartment with a water hose, these Opti's can be very sensitive to water moisture getting inside of them.
Old Jan 22, 2011 | 12:26 AM
TripleWhiteLT1
8th Gear
I haven't taken a really close look at the water pump/Optispark area yet, but I haven't seen any evidence of coolant leaking on the ground or elsewhere. I haven't touched the engine compartment at all since I got it, and it doesn't look like anyone else has either. It's not horribly filthy, but definitely not clean either.
I'll get a much better opportunity to give it a closer look this week, and will report my findings when I do so.
Old Jan 22, 2011 | 08:27 PM
Scotsman's Avatar
Scotsman
You're profile doesn't say where you're located.....If you're reasonably close to Northwest PA, I'd love to have an excuse to work on a 'vette in the winter, and opti replacement is one of my personal fav's......some will say I'm strange, and I'm still not certain why!
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If you get the 16 or 36 code again then its time to replace the water pump and opti.
Do them together.
When my opti went on the 92 I replaced it with a Dynaspark. Due to recent posts by folks that have used their service I would reccomend this unit.
If you can stand to use eBay Chandler motorsports has an inexpensive opti that folks have had good experiences with.
For my 383 I'm going with a Summit white box GenII opti because its set up for the newer style. Hope it lasts at least a season.
Old Feb 3, 2011 | 03:17 PM
ChandlerMotorsports's Avatar
0ChandlerMotorsports
Former Vendor
We offer value priced units that have a great rep. But those codes are for sure optispark deathbed confessions. Purchase link in our signature. Also you don't need to use eBay, use our signature Website should be back up again. We've been waiting for a "real" solution and we're putting it into motion. Autoparts don't work well with normal catalog systems.
Old Feb 3, 2011 | 08:07 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Thats why I had to go with the Summit Opti, your web site ordering wasn't working and I needed it NOW.
I'll try yours the next time I need one.
Old Sep 10, 2017 | 08:38 PM
tjdeftos's Avatar
tjdeftos
3rd Gear
Default 92 LT-1 w/same problem, did you resolve the problem? Thanks for any input.
Originally Posted by TripleWhiteLT1
I have a '92 Corvette with only 59k miles on it. I believe it is completely original under the hood, including the Optispark system. It has an automatic transmission. I just got this Corvette, and in the span of less than 500 miles this problem has surfaced several times.
The engine runs fine, very smooth with plenty of power, but will randomly stall while I am driving. It has stalled under multiple different circumstances(freeway, around town, etc). I will be driving along, and it will instantly die, as if someone turned the ignition off - No sputter or stumble, just shuts off. I have noticed that my tachometer needle will bounce around randomly immediately after stalling, usually for a few seconds, before falling to 0RPM.
At one point, I was running it with the hood open and peeking around to see if I could see anything obvious, and it died while I was standing there. No stumble, just shut off as if the key was turned off. For several seconds afterward I could hear what sounded like the injectors and possibly some relays cycling on and off rapidly under the hood, while my friend in the car said the tach was bouncing around the whole while. I went to the back of the car and listened and could hear the fuel pump still running. I then shut the ignition off.
It always restarts after stalling, though sometimes I have to open the throttle slightly to clear the flood condition from the injectors cycling before it will restart. I have never seen the check engine light come on while it's running, nor has it ever given me any other indication of problem except for the stalling. It has never done it with the engine cold, only when fully warmed up, though it does not always do it when warm. The first time it happened was after perhaps 20 minutes of driving, but the next day I drove it more than 170 miles and it didn't stall once. I parked it several days, then drove it less than ten miles before it started stalling, and it probably stalled on me 20 times before I made it to my destination. I would let it sit for a few minutes, then make it perhaps two miles, where it would die again. Sometimes less distance. However, two hours later(and later in the evening when it was cooler outside), I drove the entire 55 mile trip back home and it didn't stall once.
I restore classic cars for a living, but I get lost when working with these computer controlled cars. I have heard of many issues with the Optispark in this, and I can't help but wonder if this is what they typically do when they go bad. I'd like to start troubleshooting this problem, but I'm not entirely sure where to begin. How does one go about testing the various electronic components in this system? Any insight? Thanks in advance.
Did you resolve this?
Old May 19, 2020 | 04:01 AM
Ree Hazzard's Avatar
Ree Hazzard
4th Gear
Default Same problem here also.
My optispark was replaced already and the car has around 94000 miles if I recall correctly. And solution or should I go with the ignition coil? Where can I get the codes tested or how do I do that myself? I also have AC problems that it will go from cold air to hot and I have to turn it on and off before it goes cold again I believe the code on that was I'm going to say 9 it was awhile ago when I checked that. My car is parked at a friends at the moment. Thank you for any and all help. I miss driving my car!!!
Old May 21, 2020 | 03:45 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Her is some info that may prove helpful
https://tech.corvettecentral.com/201...trouble-codes/
https://www.corvettebuyers.com/c4vettes/codes.htm
