Engine Plans - opinions please!
Old Jan 17, 2011 | 06:56 PM
VtVette's Avatar
VtVette
Default Engine Plans - opinions please!
I'm working up a plan to freshen up the now stock engine in my '93 this spring. I definitely want to keep it street-able first and foremost. I don't drag or autocross. Just freshening up a bit.
My plan is as follows. Please fill in any blanks you may see:
Lloyd Elliot LE1 heads
Port match stock LT1 Intake
1.6 Roller Rockers
replace timing chain
Opti/water pump/plugs/wires changed last summer so, they are fine
I know I should change the following to take advantage of the above mod's:
Injectors? (please advise on recommended size?)
Cam? (I know about nothing when it comes to cam selection)
Tune? (I know I should get a proper tune to take advantage of the mods above).
I am also thinking I will go with 4.11 gears (it's a 6 speed).
**One caveat** - I am talking to a company in CA about a job. There is a remote possibility I may end up moving out there. Is there any way to do these mod's and keep it Smog legal? Maybe keep stock injectors/don't get crazy and, do a mild cam? Would that still pass the sniffer?
Thanks,
Old Jan 17, 2011 | 07:07 PM
rodj's Avatar
rodj
Buy LE's matching cam
# 224/230 .573/.568 112 LSA. – 1700-6100 RPM
Largest emissions friendly cam. Pretty mild idle and still able to work with stock gears
and factory converter in F or Y body. Comparable
to GM Hot Cam and Crane 846 cam.
Old Jan 17, 2011 | 07:18 PM
VtVette's Avatar
VtVette
Thanks rodj - I should probably reiterate a little bit. I agreed to purchase the heads before the opportunity in CA came up. I have since paid for the heads so, at a minimum they are going on the engine.
California is 50/50 right now. I'm supposed to travel out in about a month to visit. We do not have emissions in my current state.
To benefit the heads and cam should I look into new injectors as well?
Would larger injectors be worth it with an emissions legal tune?
Anything else I should consider doing that is not on my list?
Thanks again,
Old Jan 17, 2011 | 07:58 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Any mod that's visible has to have a CARB sticker to be legal in Cal. You can get by with a cam if its not too obvious. I have a Hotcam in my 86 and it passes smog no problem.
Old Jan 18, 2011 | 07:38 PM
mtwoolford's Avatar
mtwoolford
I agree. 96 lt4 with Hot Cam. no problem.
To Engine Plans - opinions please!
