is the throwout and pilot bearing the same w black label and blue label zf trans?
My 93 has a blue tag zf, with a remanufactured plaque.
If I install a black tag zf, for extra strength, one day ....
Will I need difft pn throwout and pilot bearing?
Also, will the flywheel housing be the same?
Suckin' gas, haulin' ass.
As far as I know, the only difference between black and blue tags is the angle of the gears inside the transmission. You should be able to use the same throwout bearing and pilot bearing. I recommend going with the needle roller throwout bearing though.
Getting a good one may not be easy....
The new AC Delco throwout bearings now are 'made in china' .
I bought one (a made in china), on my last clutch job, it had so much 'slop' in it, that I re-used my old one.
ZF Transmission
So Dizwiz24, I think you'll need a different clutch plate as well. In your cse, one with a larger diameter hole for the trans shaft.
Any educated guesses as to what the lablor might cost to get this swap done?
Thanks!
The shaft itself is the same size between blue/black. The flange that sticks out on the front of the trans is bigger on the black tag. That's the piece that the TO bearing rides on so the TO bearings are different as mentioned above. The diameter of the shaft itself, though is the same, so the clutch disks are the same.
ZF transmission Black and Blue
Thanks!
Transmission swap
Like you, I enjoy working on my car, doing brakes and bearings, but you don't need a lift for that!
I'd like to have a ballpark cost so that I can compare it to what I get quoted. (Depending on the cost, it may convince me I can do it myself!!)
Thanks!
My hat's off to you! I considered doing it myself. But without a lift and a helper, the idea of taking off the X-brace, dropping the exhaust system, removing the C-beam, and so on... with the car on jack stands, I think I may be forced to get it done outside my garage!!
Thanks!
Thanks!
[QUOTE=helphos;1576550902]My hat's off to you! I considered doing it myself. But without a lift and a helper, the idea of taking off the X-brace, dropping the exhaust system, removing the C-beam, and so on... with the car on jack stands, I think I may be forced to get it done outside my garage!!
I just swapped mine from a black to blue tag. I did it in my garage with the car on jack stands.
I got it up high enough to get a trans. jack under it. Exhaust is very easy to drop. Had no trouble
with the C beam, taking it out or reinstalling. The part that took the longest was getting the
bell housing off. This was done at a casual pace over 2 days. It's really not that bad of a job if you
get the car up high enough. The cost of the trans. jack is a LOT less than what you would pay to
get it done . Good luck with whatever you decide.
transmission work
[QUOTE=sthamby;1576552906]
Super! Thanks for that encouragement!! I have the blue tag trans sitting in my garage. Was "High enough" at the upper limits of the jack stands?
I'd love to have a smooth shifting trans in time for the spring thaw!!
(and enough money left over to put gas in the tank!)
Thanks!
Thanks!
If you plan on doing these kind of jobs at home, might I suggest a Kwik lift? It raises the Vette 20" or so which is perfect for using a creeper. By the way, it makes things much safer than jack stands. Cost around $1200. I park my Vette on mine. The first night I had mine I fell asleep under my Vette! It paid for itself when I changed my clutch 7 years ago. Just a thought for you.
[QUOTE=helphos;1576558379]
Thanks!
"High enough" was about 20 inches from the frame to floor. 4 SUV jack stands.
The car was very sturdy. I had to tilt the transmission to the side on the
jack to roll it out from under the car. The jack was $200. I don't remember
how much I gave for the stands. I've pulled the trans in 2 of my cars with
it, so imo it's paid for itself.
The throw out bearing that came in the clutch kit was made in China. I ordered
another and it was "China" too. Looked to be the same quality. The guy I
bought the car from had the clutch changed a couple of years ago. When
I pulled the trans and looked at the bearing - China. I looked for a better
quality one, but no luck. I'm not sure they exist
Thanks!
My girlfriend was not a happy camper either. She helped me 'muscle' around the heavy ZF transmission. Set that on a jack.
Dont make the mistake of thinking the jack will stay in the same position. I woke up the next morning, found the jack completely collapsed, and the ZF transmission lying on the floor next to it.
Luckily it only fell about 2 inches and fell onto the piece of fiberboard I had covering up cracks in my garage floor. It wasnt damaged.
Either im slow, or more careful. Id go bankrupt if i tried to open an autorepair shop!
I don't want to hijack this thread, but if anyone knows where to get an AMERICAN or even German or other throwout bearing besides China, please post- 2000 miles and my TO bearing is squealing like a pig. Gonna try a used one form a forum member in a few weeks.
Sorry, Mod, had to post.....
URGENT - does anyone have a part number for the throw out bearing? Black tag version
All I can find is pilot bushings
Throw out bearing
I found a centerfource N1716 at O'Rileys.
I'm going to swing by the closest store tomorrow to see if I can get it Thursday.
Otherwise it will be next week before my car will be ready
Rockauto - out of stock could be 181+ days to get one
O'Riely - A mistake on the web site, part is discontinued
Carolina Clutch - It only comes as part of a pressure plate kit, that will be $310 please.
Why can't we find a stinkin release bearing anywhere?????
I would have called ZFdoc but his web site is down
