'84 Cross Fire... Replacement?
As for tuning does the ECM really work? Where do I get a decent ECM? I was thinking of the one from DCS along with their fuel pressure fuel pressure assembly.
Renegade will have to wait. But I agree headers, tuning for now and hopefully a set of 1.6 RR's for spring. Next winter a bit moe.
DCS doesn't offer a ecm that I know of. They do offer the Ham board though. Right now you don't need a ecm so don't worry about it. If you need something down the road I would recommend dynamicefi's ecm.
Save your money for now on the intake. At this point there is no proof that the renagade puts out that much power over a ported intake on the 350 block. On that note port the living heck out of your intake. When you think your done....do it somemore. CFI-EFI is the guy to talk to about that along with TOM400CFI.
Save your money on those aftermarket chips as well. I put one in and LOST more than 30hp
Save your money on the fuel pump...right now you don't need it, save your money on the larger tb as well.
So your down to
exhaust, make it dual if you can
Do the cold air mod...which is free
Port the snot out of your intake.....free, except labor
Make your fuel pressure regualtor adjustable.... again free
Throw in a 2500 stall. $500 or less, depending on who's you use. (talk to PeteK), I use his
Set of 1.6rr's if you want.
There you got less than $1k into, and you just woke that car up...
Here is my thread.
http://forums.corvetteforum.com/c4-t...post1575063293
So these mods for the cold air and fuel pressure regulator, where do I find more info?
Honestly, I've been speaking with a local Corvette guy who said he'll build me a custom cold air intake for $250. Not bad I thought, but I' a do it yourself type of guy as long as I have some reference when doing something new. Heck, saving $250 means I can buy RR's!!!
Keep giving me ideas QWS and I'll save enough to buy more from you!
I went with the LT1 manifolds and bullet cats. Headers can be connected to the LT1 cat back easily.
Look inside your hood down towards the nose. See a oval hole?
Now, match that up with the radiator shroud... mark it and cut! thats it.
I can't post pics right now but maybe someone else could.
Chaos is absolutely right the LT-1 bolts right up. Even though ours (84) is a bit different the path is the same. Very easy to mod.
Corvette central has some dual exhaust kits along with Mid-America. Dual exhaust kit is about $300 for stainless
I saw the dual systems at CC, I think I'm going to have it custom bent locally.
You guys rock! Thank you for the help and support. I'm sure I'm not done yet though!
