wiper wiring diagram
I have a short circuit and 2 wires cuted, can't figure how the wires are connected to the fuse panel and the lever
thanks
Dan
http://www.quayle-co.com/images/90_C...er_8A-91-0.jpg
http://www.quayle-co.com/images/90_C...er_8A-91-1.jpg
I still haven't figured out how to scan and upload pages from the FSM, but per my 91 Electrical Supplement Diagram maybe this will help...
C236 Top L/H Side of Steering Column - 7 cavities - looks like 5 have wires.
Wiper Motor Module - WMM - 3 connectors - LH front of bulkhead (dash panel)
Terminal B - White wire to fuse panel 25A WPR fuse (Voltage w/key in run or accy)
Terminal C - Light Blue wire between switch assy and Pin B of the WMM C2 connector.
Terminal D - Grey Wire between switch and Pin C of the WMM C2 connector.
Terminal E - Purple wire between switch and Pin A of the C3 connector at WMM.
Terminal F - Brown Wire between switch and Pin A of the WMM C1 connector.
PM me with an email address and I'll scan the diagram/troubleshooting chart and send them to you
BTW: If you add [img] [/img] to either side of the link the image shows up in the post like this:
