ALDL Spark Adder Question
Old Jan 22, 2011 | 04:50 AM
C409's Avatar
C409
Default ALDL Spark Adder Question
I can tell when I activate the real time monitoring with the Auto X-Ray scanner ... AND when I run Datamaster , that the engine rpm flares upward . I have seen in other threads that there is a spark adder for ALDL but I don't see it anywhere on Tuner-Pro RT and 32B XDF.
My main concern/question is that if there is spark being added ... how much ? And how to tune spark advance with the added spark for ALDL ? Does it only affect idle ... or is it increased across the board ? If spark is being added globally when datalogging then the whole premise of tuning spark is corrupted by whatever value the increase is ???
Old Jan 22, 2011 | 07:18 AM
rodj's Avatar
rodj
Apparently you can remove the 10k resistor after datalogging starts and that will disable the spark adder
http://www.thirdgen.org/techboard/di...eeded-not.html
http://www.thirdgen.org/techboard/di...ble-issue.html
http://www.thirdgen.org/techboard/po...665-post2.html
If you have tuning equipment you could run a 6E xdf and bin in place of your 32B.
6E has provision for adjusting the spark adder value
