Bumper alignment help needed
Old Jan 23, 2011 | 09:55 PM
beche's Avatar
beche
Default Bumper alignment help needed
I need some help with aligning my drivers side bumper which has a 1/4 inch gap from two previous over parking and hitting the underside bar.
I did a detail search and i see post but no answers.
Old Jan 23, 2011 | 10:21 PM
383vett's Avatar
383vett
There are shims on each side between the bumper mounting bracket and the frame. There are 4 bolts on each side. The bolts need to be loosened, and the shims will slide out from the side. A couple of them are hard to access, but they are doable. I just had my front bumper off a few weeks ago and was able to remove 20 lbs of the front end so it's still fresh in my mind. Good luck.
Old Jan 23, 2011 | 10:27 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Search for "Front Bumper" in titles only on the C4 Tech and General forums. You'll find plenty of posts addressing adjustment procedures.
I got 158 hits to look thru.
Edit: You could also send Sam Lam an email. He used to have a complete write-up he would email.
To Bumper alignment help needed
