Radio Removal
Old Apr 10, 2002 | 04:47 PM
SteveS66's Avatar
SteveS66
Default Radio Removal
How do I get the radio out of my '94? My CD player doesn't work so I need to get it out of the dash and send it somewhere. It is supposed to be a pretty easy job but I'm not quite sure how to get the dash pieces out of the way to slide the unit out. Can anybody give me some quick instructions?
Thanks.
Steve
Old Apr 10, 2002 | 04:53 PM
Gozar's Avatar
Gozar
Cruise-In IV Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Default Re: Radio Removal (SteveS66)
1) Remove the lid cover of your center console storage (9/32 socket will work) 4 or 5 screws I believe.
2) Remove the two torx screws in your air vent above your warning light panel.
3) Remove the 9/32 screws under the drink holder and the ones around the center console lid and that should allow you to life up the area around your shifter.
4) Remove the 9/32 screws under the shifter cover towards the front that hold down your radio panel cover. Should be three of them.
5) Remove radio faceplate cover and remove fasteners.
That should roughly do it.
[Modified by Chris Maynard, 12:59 PM 4/10/2002]
Old Apr 10, 2002 | 08:32 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Radio Removal (Chris Maynard)
Click here:
http://www.corvetteradios.com/corvetteradios__1.htm
Old Apr 11, 2002 | 03:56 PM
SteveS66's Avatar
SteveS66
Thanks. That's exactly the info I was looking for.
Steve
To Radio Removal
