air pump delete
Old Jan 24, 2011 | 02:16 PM
pmhc's Avatar
pmhc
Default air pump delete
Thanks for the reply but I can't find the air pump eliminator article in the c4-tech with a number of 2748589. Also after I take the a/c and the pump off do I need to reprogram the computer? Also what is the heater hose and metal line combo going from the a/c firewall down to above the oil filter for? I'm also adding headers will that affect the computer etc.
Old Jan 24, 2011 | 04:07 PM
korvette4u's Avatar
korvette4u
Check your mail box..
or message me
Old Jan 24, 2011 | 05:56 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
After I take the a/c and the pump off do I need to reprogram the computer?
No
Oil cooler (hose) and (metal) air tube to the catalytic converter.
Not necessarily. Depends on the O2 sensor setup.
Old Jan 24, 2011 | 06:12 PM
vetteoz's Avatar
vetteoz
I can't find the air pump eliminator article.
Also after I take the a/c and the pump off do I need to reprogram the computer? .
If you remove the A/c compressor you don't need the air pump eliminator.
Read the AC delete links I posted for you in your other question
The money for the eliminator pays for the new water pump needed ( with change )
To air pump delete
