Started taking the engine apart.
Old Apr 10, 2002 | 08:40 PM
scorp508's Avatar
scorp508
Default Started taking the engine apart.
Alright everyone, now is the time. :) I started taking the engine apart today after work. I got out....
Radiator
Ignition Wiring
EGR System
AIR System
All vacuum lines
One valve cover
Man, I could not believe it when I pulled the passenger side valve cover. Everything looks BRAND NEW. Keep in mind there are 166k miles on this damn thing. All the rockers, springs, retainers, everything look to be in completely excellent condition with just a slight goldish haze of oil coloring on them.
So this might take a while, I only have about 2.5 hours of daylight each day when I get home as long as it isn't raining.
Anybody know a good way to get the injector harness to pop off those bolts on the drivers side? The tabs do NOT want to come up no matter what angle I pry at them from.
Old Apr 10, 2002 | 09:23 PM
Corvette_Z51's Avatar
Corvette_Z51
Default Re: Started taking the engine apart. (scorp508)
Man, if it wasn't so far I'd come up and help ya! Don't worry, in no time at all it will look like this soon:
Old Apr 10, 2002 | 09:25 PM
scorp508's Avatar
scorp508
Default Re: Started taking the engine apart. (Corvette_Z51)
Ahhhhhhhhhhhhhh!!!!! I Hope not. Not THIS time at least. :D
Any idea how the heck to get the driver's valve cover off. There is a metal vacuum line running from the brake booster to the plenum and it trails right over the back edge of the cover.
Old Apr 10, 2002 | 09:28 PM
J Z06's Avatar
J Z06
I've been wanting to say this for a long time,and you can too next time you see me race!
It's about time!!!! :jester :D
Old Apr 10, 2002 | 09:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Scorp that injector harness is a PITA. It gets brittle over time; I broke several retainers getting them off the bolts.
I didn't notice any brownish film on my heads till I pulled the pushrods. They had some coating, guess they run cooler being farther from the "fire".
Are you going to pull it or do the cam, etc in the car; what is the "etc"?
Old Apr 10, 2002 | 09:34 PM
scorp508's Avatar
scorp508
It's being done in the car. The etc is....
D-Port heads : ported/polished, 3-angle valve job, new valve guides
2.02/1.60 Manley Pro-Flo Valves
Titanium Retainers
New Lunati Double Valve Springs
Heat Treated Pushrods & Guide Plates
Comp Cam Pro Magnum 1.6:1 Roller Rockers
SuperRam Plenum, Runners, Intake Manifold
LPE 74219 Camshaft
Hooker 2149 Headers w/Custom Y-pipe
Adjustable FPR
Custom EPROM
All ARP fasteners & Fel-Pro gaskets. It should be interesting.
Old Apr 10, 2002 | 09:50 PM
jeffie86/96's Avatar
jeffie86/96
Default Re: (scorp508)
Good luck Scorp, mine looks like the engine bay up above right now, and has for quite some time. It all depends on weither your engine is driven properly and the oil changed regularly as to the condition inside. Factors like climate have a lot to do with it, my 76 BMW with 136000miles looked like brand new when I pulled the valve cover. Just remember that oil must get hot to clean the engine, so short trips really kill a motor. :smash:
shera's Avatar
shera
Scorp,
To get the metal hose out of the way for the removal of the drivers side valve cover try this. Remove the rubber hose that goes to the power brake booster and bend the metal hose up. It is in a friction type clamp bolted to the end of the head.
For the injector wires the plastic tabs that hold it to the monifold will most likely break. Not a big deal, I don`t think that you can use it with the super ram anyways. They can just lay in there. Been there done that in my 87.
Old Apr 10, 2002 | 09:57 PM
65Z01's Avatar
65Z01
Wow you do have a few things on the plate!
Remove the brake booster line from the back of the plenum and move it out of the way. Loosten the alt & AIR pump brackets and move these forward slightly. That should be enough to get the valve cover off.
BTW, with a 2.02" intake I assume you are also doing new valve seats.
If that cam is pretty big I can let you have my 7/16" 1.5:1 ProMagnums at a good price (still in the bubble).
Old Apr 10, 2002 | 10:01 PM
scorp508's Avatar
scorp508
Yup, we already did a new valve seat job on the heads.
The cam is .525 lift with 1.5s and .560 lift with 1.6. :) I've got 7/16" studs already. Thanks though!!
Old Apr 10, 2002 | 11:44 PM
Vic'89's Avatar
Vic'89
Default Re: Started taking the engine apart. (JD 90 383)
You can say that again !
Anyway, good luck with the tear down. Give us some progress reports.
Vic
Old Apr 10, 2002 | 11:54 PM
vader86's Avatar
vader86
Default Re: Started taking the engine apart. (Vic'89)
finally scorp is putting the SR on :cheers: :cheers:
Old Apr 11, 2002 | 03:00 AM
Bender's Avatar
Bender
I’m just curious, did you do a compression test before you ripped it apart? That’s a lot of miles. Do you ever sleep :confused:
Good luck with everything, I hope it turns out great :cheers:
Old Apr 11, 2002 | 10:22 AM
WINNER's Avatar
WINNER
Default Re: Started taking the engine apart. (Quasar92Blue)
Old Apr 11, 2002 | 10:33 AM
Goody's Avatar
Goody
Default Re: Started taking the engine apart. (WINNER)
Boy, it just never ends. But, looks to be a real screamer when it's done....well, done till the next time. :jester
Old Apr 11, 2002 | 12:58 PM
dgoodhue's Avatar
dgoodhue
I just moved the one accessory bolt and I maneuvered it out. I had a lot harder time remving the passenger side.
To Started taking the engine apart.
