Problem retrieving codes 89 vette
Old Jan 27, 2011 | 06:28 PM
JinksEll's Avatar
JinksEll
Cruising
Default Problem retrieving codes 89 vette
When I short the A&B pins and turn the ignition on the fan starts to run but no codes are displayed. Any one had simular problem?
Old Jan 27, 2011 | 06:51 PM
vetteoz's Avatar
vetteoz
Does the SES light flash at all?
Old Jan 27, 2011 | 08:31 PM
JinksEll's Avatar
JinksEll
Cruising
no it doesn"t
Old Jan 27, 2011 | 10:19 PM
vetteoz's Avatar
vetteoz
Originally Posted by JinksEll
no it doesn"t
Does it light up when you turn the key on? ( without jumper )
Old Jan 28, 2011 | 07:05 PM
JinksEll's Avatar
JinksEll
Cruising
when I open the door "Security" starts to flash. When I turn the key to ON anti lock, low collant and fasten seat belt comes on then goes off. The only thing that stays on is the battery symbol
Old Jan 29, 2011 | 01:07 AM
rodj's Avatar
rodj
When I turn the key to ON anti lock, low collant and fasten seat belt comes on then goes off. l
Most likely SES bulb is blown , should light up when key tuned on like the other lights,
The fact your fan runs indicates the ECM has gone into diagnostic mode correctly when you jumpered the ALDL
To Problem retrieving codes 89 vette
