Factory Radio Gets Loud
Old Jan 27, 2011 | 07:01 PM
vettme's Avatar
vettme
Default Factory Radio Gets Loud
This is odd. When I back up my stero (every now and then) will go full blast, for a sec or so. Any ideas?
Old Jan 27, 2011 | 07:12 PM
Sandpiper59's Avatar
Sandpiper59
What year, what stereo?
Does it have the volume that changes with vehicle speed? If so you might have issues with the speed sensor..
Old Jan 27, 2011 | 07:15 PM
96GS#007's Avatar
96GS#007
I'm assuming you have a later C4, putting the year and engine type in the post is helpful.
There are typically three reasons...
- The "Speed Compensated Volume" (SCV) is failing within the radio itself. This requires the head unit to be rebuilt
- The Vehicle Speed Sensor (which is what the SCV function is keyed to) is failing. Typically you will see your speedometer do some odd things if the VSS is failing (ie the digits are slow to respond, incorrect speed readings, etc).
- Electrical connector/wiring issue
Old Feb 8, 2011 | 05:10 PM
vettme's Avatar
vettme
Sorry for the lack of info, its a '96 LT-4 . from the Post so far it sonds like the (SCV) is the issue . Thanks
To Factory Radio Gets Loud
