c4 motor wiring harness
Old Jan 30, 2011 | 02:42 PM
edddie k's Avatar
edddie k
Default c4 motor wiring harness
i just got my 85 vette ,i got the motor and tranny out to rebuilt. The problem is the entire wiring harness has been mickey mouse. I can not even get the main connectors off. Anyone know where i can get a new motor harness?
Old Jan 30, 2011 | 05:17 PM
rodj's Avatar
rodj
Used only
Now would be a good time to convert to the 86 -89 TPI computer and wiring ; cheaper for parts in the long run
The one year only MAF burn off setup in the '85 runs $150+ used ( if you can find one).
The later cars use $15 relays
Check out the For Sale dept for someone parting out a 86 - 89 car
http://forums.corvetteforum.com/c4-p...ale-wanted-55/
Old Jan 30, 2011 | 05:51 PM
Marv02's Avatar
Marv02
I sure if you gave Painless wiring up they can build you a wiring harness it wont be cheep that for sure.
Old Jan 30, 2011 | 05:59 PM
rodj's Avatar
rodj
Originally Posted by Marv02
t wont be cheep that fro sure.
So why not get a stock harness from a part out car then?
Or you buy a $300 standalone '165 engine harness and wire like a retro fit car
Old Jan 31, 2011 | 08:27 PM
edddie k's Avatar
edddie k
I can not find a parts out car what is a standalone
Old Jan 31, 2011 | 08:52 PM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-p...-you-need.html
http://forums.corvetteforum.com/c4-p...-out-85-a.html
Old Feb 1, 2011 | 12:35 PM
edddie k's Avatar
edddie k
Default C4 motor wiring harness
i just got a hit about one ,he wants 500.00 for it used. Is that a good $
Old Feb 1, 2011 | 03:28 PM
SunCr's Avatar
SunCr
I'd never buy used if new is available and for $500, the harness must be extremely hard to come by. The information sensors used to for fueling use resistance to control voltage drop. Copper wiring, no matter how good the insulation (and sometimes it wasn't so great from the Factory), will deterioate with age adding resistance to the circuit which will skew sensor values.
Old Feb 1, 2011 | 05:35 PM
LD85's Avatar
LD85
go here and do not go to Painless, they are canned, and do not fit the stock Vette plug positions.
www.jimsperformance.com
He will rebuild yours to new for @ $150
To c4 motor wiring harness
