Emulation
Old Jan 30, 2011 | 11:03 PM
90C4sRule's Avatar
90C4sRule
Default Emulation
Can a eprom chip be removed from a memcal and replaced with an EEprom instead of using an adapter? Then reflashed with a new bin through the ALDL while in the ECM?
Old Jan 31, 2011 | 12:37 AM
rodj's Avatar
rodj
Possible but you usually screw up the terminals in the base levering the old chip out which is why most just cut the pins off the stock chip and install a 28 pin socket that allows for easy EEprom removal
No
The chip has to be programmed in a external burner.
If you have a 94+ PCM with internal memory you can reflash memory ( with correct software ) through the ALDL
http://forums.corvetteforum.com/1576629092-post3.html
