hotter plugs for 86 vette
Old Jan 31, 2011 | 07:11 PM
reddirtcowboy's Avatar
reddirtcowboy
Default hotter plugs for 86 vette
need a plug a Degree hotter than stock.what shuld i use. for TPI 350? need to burn off a little oil on #7 and #8 pistons
Old Feb 2, 2011 | 04:30 PM
bwiencek's Avatar
bwiencek
What are you wanting to know??
Just head to the parts store and ask them for a plug that's one heat range hotter than the factory plug - some use higher numbers for hotter, some lower numbers - going to have to know what brand plug you're using (or just have the parts guy look in the book - there will be a chart in the back with the heat ranges decoded...)
Old Feb 2, 2011 | 04:34 PM
reddirtcowboy
i asked any they did not know,i have the stock gm plugs in it, i need a part # for a hoter plug so it will burn off the oil and keep it from fouling.thanks
Old Feb 2, 2011 | 04:42 PM
Muffin's Avatar
Muffin
Change your parts store now, do not wait. The guys you are dealing with are dangerous.
Old Feb 2, 2011 | 04:47 PM
bwiencek's Avatar
bwiencek
Well they surely don't know how to look in a BOOK - not every tidbit of information is on the computer screen in front of them....
What brand of plug do they carry (or do you want to buy)?
reddirtcowboy
i know! it is a napa store i was not happy.and then they told me to go to a mustang forum and ask i was like wow realy? what shuld i do?
Old Feb 2, 2011 | 04:48 PM
reddirtcowboy
what ever works best
Old Feb 2, 2011 | 04:58 PM
bwiencek's Avatar
bwiencek
IIRC for spark plugs:
Autolite, Bosch, Champion - Higher numbers = hotter plug
NGK, Denso - Lower numbers = Hotter plug
Go have them look up a stock plug then when they get the part number of the plug have them go up or down to get a hotter plug (remember most parts stores use a stock number for the plug so they may have to look at the actual plug to get the spark plug's number)
Old Feb 2, 2011 | 05:17 PM
LaVidaLoca's Avatar
LaVidaLoca
Found an interesting web site by NGK with a lot of info about spark plug heat ranges and the reasoning behind them:
http://www.ngksparkplugs.com/tech_su...x.asp?mode=nml
Old Feb 2, 2011 | 05:18 PM
reddirtcowboy
ok thanks
Old Feb 3, 2011 | 02:25 AM
oldalaskaman's Avatar
oldalaskaman
maby fix the valve seals? if its real light, if not hotter plugs wont do anything either.
Old Feb 4, 2011 | 08:18 PM
davenbocafl's Avatar
davenbocafl
sounds like you have leaky injectors
Old Feb 4, 2011 | 10:48 PM
bwiencek's Avatar
bwiencek
I'm hoping that he's done the diagnostics and it's not fuel fouled - I'm assuming he's truely treating it as a band-aid for a true oil consumption problem (which at the point it fouls plugs it's gotta be chugging oil at least a quart per fill-up!) and this is really only temporary until the funds allow for a real fix (either valve guides if it's coming from the heads or rings if it's coming from the bottom end - neither which is a quick or cheap fix...)
Old Feb 5, 2011 | 12:19 AM
John A. Marker's Avatar
John A. Marker
If your plugs (7 & 8) are oil fouled, the hotter plug will not help for long. The problem is a bad intake gasket. A well known Chevy problem for years. Replace the gaskets. Use the Right Stuff and dimple the china wall front and rear of the block.
Old Feb 8, 2011 | 10:06 AM
reddirtcowboy
it is to get me by for a month or so till i can rebulid it. I'm taking it up to a 383 it sounds like the best way to go. i would like to put out about 450hp to 500hp at the crank
Old Feb 8, 2011 | 11:53 AM
9T3VETTE's Avatar
9T3VETTE
Champion, NGK, DENSO - higher number = colder plug
Bosch - higher number = hotter plug
I can only speak about application of DENSO spark plugs. Your stock plug that you have should be a HR16 (in DENSO terms). Therefore you need a 14HR plug if you want to go higher. Unfortunately, DENSO does not produce a 14HR spark plug for the aftermarket.
DENSO heat range #14 is equivalent to #9 for Bosch, #4 for NGK, and #16,14 for Champion.
Hope this helps a bit.
Old Feb 8, 2011 | 12:29 PM
DAVEY420's Avatar
DAVEY420
3rd Gear
985 is next hotter Autolite then 3926. the 985 has some type of special tip on it
Old Feb 8, 2011 | 12:31 PM
reddirtcowboy
ok thanks
To hotter plugs for 86 vette
