Cam in More Performance 396?
Old Apr 11, 2002 | 06:30 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default Cam in More Performance 396?
What cam does More Performance use in there 396 LT-1 motor? They have regular camshaft, 494 hp, and a larger 532 hp? Anyone have one or the other or know the specs?
Old Apr 11, 2002 | 06:42 AM
Zix's Avatar
Zix
Default Re: Cam in More Performance 396? (steve40th)
They usually use a custom grind unless the customer specifies something different which is pretty rare. You would have to call them to find out the specs, they are pretty liberal with the info. I called them to ask about the specs on the cam in their CNC LT4 top end package and they spent a good 30-40 minutes on the phone with me even though I told them that I was just looking for a cam and not the entire package. Give them a call, you won't regret it.
Jay
Old Apr 11, 2002 | 07:55 AM
vettmanlt4's Avatar
vettmanlt4
Default Re: Cam in More Performance 396? (Zix)
Jay,
So what was their cam spec recommendation on the LT4 CNC Top End Package?
Old Apr 11, 2002 | 09:43 AM
vader86's Avatar
vader86
Default Re: Cam in More Performance 396? (vettmanlt4)
they only list custom grinds in their packages
Old Apr 11, 2002 | 01:25 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Default Re: Cam in More Performance 396? (vader86)
My old roommate's father had a 383 built by them and used a Crane 222/230 112lsp lift I think was in the 560s.
Old Apr 11, 2002 | 05:02 PM
Zix's Avatar
Zix
I don't have the specs in front of me, I'll have to find them...but I went with a Crane cam #109831, which I remember was pretty similar to their custom grind. You can look at the specs of that cam here...
http://www.moreperformanceinc.com/lt1cams.htm
One of the main reasons I didn't go with their custom grind was because they couldn't ensure me that it would be able to pass emissions.
Old Apr 11, 2002 | 07:42 PM
365ZUM's Avatar
365ZUM
Cruise-In III Veteran
For cams, MORE offers three "house" cams designated- Baby cam (very similar to the Hot Cam), medium (the 494hp quote), and their "Big Boy" cam (532hp); among their other custom grinds. Unfortuneately, you'll have to call them for the specs. My car is there now. Good luck! :cheers:
Old Apr 11, 2002 | 07:48 PM
luvmy92's Avatar
luvmy92
Default Re: Cam in More Performance 396? (365ZUM)
The mild Cam that they use in their LT1 top-end kit is a custom grind Comp Cams 210/224 @ .050 w/112 LSA. I think the lift numbers are .534/.532 w/1.6 Roller Rockers. I believe the beefier Cam with this kit is the Crane 222/230.
Mike
Old Apr 11, 2002 | 10:51 PM
96LT1's Avatar
96LT1
Default Re: Cam in More Performance 396? (luvmy92)
Hey Mike,
How is it going? Which cam did you go with on your top end package?
I've got my '86 at More now. Mike is doing the entire 396 thing on it.
Are you going to be able to make it up here this year? We miss you at ODS.
Old Apr 11, 2002 | 11:12 PM
luvmy92's Avatar
luvmy92
Default Re: Cam in More Performance 396? (96LT1)
Hey Mike,
Good to hear from you. I have the mild cam mentioned above. BTW, I miss ODS too (and the guys). If you haven't heard, I am selling my vette to purchase a ZR-1. Here is the link...
http://forums.corvetteforum.com/zerothread?id=277084
I hope to make it up there for the Spook this year...
Mike
To Cam in More Performance 396?
