header problems guys. Alternator bracket problem
Old Feb 2, 2011 | 09:10 AM
kylebuck89's Avatar
kylebuck89
St. Jude Donor '09
Default header problems guys. Alternator bracket problem
I'm putting long tubes on my Lt4 and Im having trouble with the alternator bracket that ran to the exhaust manifold.
Anyone know how to beat it?
Old Feb 2, 2011 | 09:17 AM
ch@0s's Avatar
ch@0s
What kind of problem?.. Can you post a picture?
Old Feb 2, 2011 | 09:20 AM
kylebuck89's Avatar
kylebuck89
St. Jude Donor '09
Yeah I sure can.
Old Feb 2, 2011 | 10:40 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Leave it off. I just used the upper brace on my 92 when I put the headers on. Several hours of race usage and no issues.
Old Feb 2, 2011 | 11:04 AM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
Jaa1992, there have been documented problems with the alternator case cracking in half without this brace. Yours hasn't broken, yet.
Jobuck, this is how I did mine:
ENSURE THE BELT IS NOT TIGHT DURING FABRICATION!!!
Cut the tube off the original manifold, and use old bolt and nut.
Cut the bracket in half, and bend the ends so that they are aligned.
Next, cut a piece of steel dowel or tube to length:
Tack weld it in place, remove it then weld it up. Paint it to your taste to prevent rust.
Finished product:
This is the easiest way to do it with Headman Elites. There was another way to do it using the old plug wire loom hold holes in the head, but that would require that the header flange to be cut, and I didn't want to do that.
Old Feb 2, 2011 | 11:45 AM
korvette4u's Avatar
korvette4u
Finished product:
good job!!! just one question? does your immediate steering linkage near the rag joint interfere with the header??
i used this double bracket to eliminate alternator support:
Bracket upgrade
Old Feb 2, 2011 | 11:54 AM
STL94LT1's Avatar
STL94LT1
I've ran my car for eight years without the bracket and without problems. The LTx cars have an upper brace as jaa' described, as opposed to the pictures posted.
Old Feb 2, 2011 | 12:53 PM
383vett's Avatar
383vett
Mine works like this.
Old Feb 2, 2011 | 01:04 PM
kylebuck89's Avatar
kylebuck89
St. Jude Donor '09
ok ... the bracket runs to the second header bolt from the front.
This is the bracket
this is how the bracket looks on a stock car.
Old Feb 2, 2011 | 03:59 PM
Flame Red's Avatar
Flame Red
On an L98 you can run into issues without the bracket (different alt over the LT1/Lt4). I think they call the C130? I cannot tell you how many "stock" alternators I went through before I finally bought a PowerMaster alternator. It lasted ten years and would have lasted a lot longer except I screwed it up because I experimented with belt routing.
To header problems guys. Alternator bracket problem
