MAP Sensor on 91 [Question]
Old Apr 11, 2002 | 12:02 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default MAP Sensor on 91 [Question]
how do you know if it is bad or not? what symptoms will the car have if this sensor goes bad?
[Modified by Marcho Polo, 10:04 AM 4/11/2002]
Old Apr 11, 2002 | 01:04 PM
gcrouse's Avatar
gcrouse
Default Re: MAP Sensor on 91 [Question] (-=Jeff=-)
If it's completely toast your engine won't even run. The MAP sensor measures engine load, and that plus rpm are primary inputs to the ECM to look up spark/fuel maps. If it's sort of working, or if the vac hose is leaking, etc, it might barely run, hunting up and down for idle, stall when you open the throttle.
If you have a hand vacuum pump/bleeder and a multimeter you could test it.
Old Apr 11, 2002 | 01:13 PM
ZylaRace's Avatar
ZylaRace
Default Re: MAP Sensor on 91 [Question] (gcrouse)
A bad MAP can totally hose the engine operation. It is the main ECM input to control fuel output.
Totally bad, and you will get a TCode.
Old Apr 11, 2002 | 06:42 PM
devilfish's Avatar
devilfish
Default Re: MAP Sensor on 91 [Question] (ZylaRace)
the engine will run without the MAP. Mine did.. :) But you will get a "service engine soon" light.
Old Apr 11, 2002 | 08:31 PM
VAHROOM's Avatar
VAHROOM
Default Re: MAP Sensor on 91 [Question] (devilfish)
While it is true that the engine will run. It will go to the "limp home mode". As we all know limp is bad. (Or so I hear)
Will a MAP on the way out cause poor performance?
[Modified by 90_roadster, 6:32 PM 4/11/2002]
Old Apr 21, 2002 | 04:53 PM
VAHROOM's Avatar
VAHROOM
Default Re: MAP Sensor on 91 [Question] (90_roadster)
Well will it?
Old Apr 21, 2002 | 07:23 PM
-=Jeff=-'s Avatar
-=Jeff=-
I don't know.. but my trouble was my VE tables in my PROM.. stock tables and my set-up don't like each other :)
Old Apr 21, 2002 | 07:53 PM
VAHROOM's Avatar
VAHROOM
Hahahaha thanks Jeff. That was my way of getting it back to the top.
I am glad you found the root cause of your problem.
Old Apr 21, 2002 | 11:12 PM
Sam Lam's Avatar
Sam Lam
Jeff: It gets darn expensive replacing sensors when you think they "may" be going bad. There is another altenative that is not quite as expensive as just buying a new one and see what happens. Mid America Direct sells sensor testors for about $12 to $15 depending on what sensor you suspect. These along with a good Volt/Ohm meter will "tell the real story". I just bought a set of testers for my '89 for about $85 total. I had a very rough idle and the sensor testors led me to a new IAC motor/valve and my problem was solved!
Regards, Sam
To MAP Sensor on 91 [Question]
