85 not run for 7 years
I am new to this forum. I have been asked to help get this 85 running, it was owned by a guy who passed away over 3 years ago, and it sat in the driveway for about 7 years with out being started or even rolled. I know I need to drain all fluids. engine oil, filter, trans fluid and filter, coolant, and re-end oil, and even the gas tank, my question is how hard is taking it down. Have taken down gas tanks on full size trucks before but never a Corvette, I would guess I need to get as much of the old gas out as possible, also, not ever working on one before, is the fuel pump in the tank like most Chevy's, and should replace fuel pump and sender to play it safe ? Anything else should I look for before starting, I know it will need new battery and 4 new tires. I was a nice 85, as the guy had his own Corvette shop years ago, and it has the 93 nose, and tail, and shark gills, and mods to the motor and ECM.
Thanks in advance for your help
Also you can dump 2 or 3 gallons of new gas and drain it the same way easy.
Put a couple more gallons of new gas in to the car and new filter remove the fuel line at the injector rail before you turn the key to prime the system to get rid all of the bad old gas out all the fuel lines before you fire it for the first time.
I also made sure the old oil looked good and ran it with the old oil for a couple minute before I put new oil in the cat just to make sure it would run.
No reason to put new oil in it if the motor shot.
Just make sure it dont knock and sounds like it need to be pulled I not saying drive it with old oil just to see if it runs.
Same with the trans and the rear diff make sure they work before you fork out the cash.
Dont forget about the power steering Fluid and brake fluid change.
I also changed out the brake rottors mine were very rusty.
thanks for the input and advice
JS
Since you've got NO gauges - pull the factory senders for the oil press and water temp and hook up a CHEAP gauge set (Harbor Freight $18 set of 3 quality even) - just to have something there to monitor the engine to get it running.
