Sawblade question...94LT1
Old Apr 11, 2002 | 01:16 PM
Bill94LT1's Avatar
Bill94LT1
Default Sawblade question...94LT1
It appears my sawblades are mounted/running in the wrong direction. Assuming the wheels and tires are directional, is there any risk of damage if
the wheels are mismounted, but the tires are in the right direction? Is it worth
paying to have all the tires remounted and wheels rotated to the correct position? For what it's worth, I have the LTPWS and would probably have to pay for someone's expertise to get everything remounted without damage to the sensors. :cry :cry :cry
Old Apr 11, 2002 | 01:31 PM
Dan Parker '96's Avatar
Dan Parker '96
Default Re: Sawblade question...94LT1 (Bill94LT1)
Prices will be different wherever you go, but around here a dis-mount, mount and balance will be about $15 a wheel.
The LTPWS sensors aren't a big deal. You'll just have to show them where on the wheel to break the bead. The sensor is mounted opposite the valve stem (if the stem was at 0 degrees the sensor is at 180). So don't break the bead there :)
Having the wheels running in the wrong direction won't physically hurt anything but (to me anyway) it looks kinda silly.
Old Apr 11, 2002 | 01:33 PM
John Row's Avatar
John Row
It doesn't hurt anything. It just looks odd to another C4 owner (no one else would notice).
The wheel is designed to pull air from around the brakes. Due to the turbine shape, running backwards probably doesn't move any air at all. It might keep the brake dust off better.
Just don't post a picture on the forum, you'll get a couple hundred "Did you know your wheels are on backwards" instant messages.:D
Old Apr 11, 2002 | 01:45 PM
35th's Avatar
35th
Default Re: Sawblade question...94LT1 (John Row)
The cost of the re-mount should fall back on them :yesnod: if there the 1's that mounted them wrong in the 1'st place. I would call them on it 1'st and :eek: what they have 2 say about it. :cheers: :seeya
Old Apr 11, 2002 | 02:50 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: Sawblade question...94LT1 (35th)
Last time I bought tires the morons put the fronts and the back spinning in opposite directions! :mad
Old Apr 11, 2002 | 05:17 PM
R23HTC's Avatar
R23HTC
Default Re: Sawblade question...94LT1 (BrianCunningham)
I bet that handled weird! :mad
As far as the sawblades are concerned, if it was me, I'd have them all mounted properly. :yesnod:
Old Apr 12, 2002 | 03:45 AM
AquaMetallic94LT1's Avatar
AquaMetallic94LT1
I had mine done once and the morons put the front wheels on the back and the back on the front. wtf :confused:
Old Apr 12, 2002 | 10:19 AM
92TripleBlack's Avatar
92TripleBlack
Default Re: Sawblade question...94LT1 (AquaMetallic94LT1)
Make sure the tires aren't mounted backwards also. You may have the tires on the wheels correctly and the wheels incorrect. This could damage your tires.
Old Apr 12, 2002 | 01:56 PM
Bill94LT1's Avatar
Bill94LT1
Default Re: Sawblade question...94LT1 (92TripleBlack)
I just checked and the tires are mounted in the right direction :yesnod: but the wheels are on the wrong side :mad . Guess I'll have to live with the "different" look, until I need new tires :cry :conehead . I don't know if it's worth $80-100 just to be visually correct. Thanks for your replies!
Bill
Old Apr 16, 2002 | 02:35 PM
BETA's Avatar
BETA
Hey Bill.....I fixed mine.....the photo below is how my SawBlades were when I bought the car.......apparently "BoneHeadism" is catching at some of the fix it shops.
Old Apr 16, 2002 | 03:01 PM
TravisD's Avatar
TravisD
Default Re: Sawblade question...94LT1 (vette5)
When I bought mine the 9.5" rears were on the front, and the 8.5" fronts were on the rear. :rolleyes:
Dealer was throwing in new rubber though so that only lasted until the tires arrived and were mounted...
To Sawblade question...94LT1
